I just picked up a 95 Ranger with 40k on the odometer. Having just taken possessionof the truck, I just have to change out all the fluids. The owners manual calls for Mercon ATF in the manual transmission but I have a couple quarts of Mercon V sitting in the garage that I would like to use instead of buying more of the older stuff.
Can I use Mercon V for this application? I think I can because the Mercon V is a newer spec but I want to make sure. My understanding is you can use Mercon V for a Mercon application but you cannot use Mercon for a Mercon V application. Correct?
