There is no recycling centre in my country that collect used oil filter... only used oil recycler...
I tried my best to drain off the oil by leaving the oil filter upside down for months before i threw it off to the garbage bin. which i feel very guilty as i know im gg contanminate the ground water as the garbage will go to the landfill...
I was thinking, is it possible to clean up the oil filter by rinsing the oil filter with petrol/ kerosene, then drain off the eccessive oil+kerosene mix before i reuse the oil filter? will the petrol/ kerosene damage the filter element?
i know that the moden oil filter is not meant to be reuse, but if i could extend the lifespan of the filter by 2x, i could at least reduce the amount of pollution..
any comment?
any comment?
