Originally Posted By: Char Baby
When reusing the oil filter for a second OCI, is it recomended to remove the oil filter, drain it and reistall or just leave on the filter, drain the oil and fill 'er up?
I have, without a problem. Some have reported the base gasket leaking, so you'd need to keep an eye on it after you re-install it. I don't over-tighten to begin with, so maybe that has something to do with it.
Originally Posted By: HTSS_TR
I just leave it on, the reason was the oil in the filter didn't drained out because of the ADBV. There is small gain when you remove the filter, about 2-3 oz drain out from the filter hole.
That depends on the orientation of the filter. With a filter in a horizontal position or pointed down, I've gotten quite a bit more out that just what was held by the ADBV. Also, if I'm pulling a filter to re-use it, I'll also push open the ADBV and remove that oil as well.
