Oil filter — clean/empty — reuse
Ottawa, Ont CANADA
Yes…. its beckons to be asked… WHY…??? just why?? Or why bother…?? Yes, go ahead and roll your eyes here… LOL Here is it…. I have a new to me, Husq lawn tractor [ 59 hours on the clock when I got it.. ] has gas seeping in crankcase issue, I discovered when I did my first OCI. Yes most likely a float/needle issue I plan to address as soon as I can find a suitable replacement carb. Since then, I've installed a gas shutoff valve on the fuel line and did 3 OCI. On one of those OCI I drained and reinstalled the same filter as it had less than one hour service, so IMO its still a new filter…. gas in new oil smell remains - suspect it came from the filter and possibly residual gas-oil in the sump.. This filter is now drained [ 95%? ] sitting open in my shop… just letting it air out.. until next year or whenever.. Has anyone ever tried to clean/clear out a filter of oil/contaminants…?? Yah it seems silly… thought id ask before I start tossing new filter in the recycle program… im funny that way. Any constructive or face-palm comments welcome… ... Cheers J.
wwillson
Staff member
Naperville, IL
I don't know how you would remove contaminants without destroying the filter, but what solid contaminants could there be? Gasoline will eventually evaporate out over a few weeks. With one hour on the filter, it's brand new and can be used.
2K2AcuraTL
Ottawa, Ont CANADA
indeed i wasnt worried too much about solid contaminants... it was more about removing the little gaz contaminated oil left behind.. also, as mentioned above... i suspect the gas will vap-off over time
PNW
Only way you could "flush" out the filter of old "gassy" oil is fill it with new oil through the center tube until it won't take any more. Then turn it base down and let the oil drain out. After that, take a couple of Q-Tips and bend them in half and carefully put them into a couple of the ADBV inlet holes in the base to crack open the ADBV, then put the filter base down in a funnel and let the rest of the oil drain out. That will only flush out any old oil. Anything debris trapped in the filter media will stay there, which won't hurt anything. Or you could just use a new filter since it sounds like a lot of hassle. grin2
Western S.C.
... Gasoline will eventually evaporate out over a few weeks. With one hour on the filter, it's brand new and can be used.
Exactly. There won't be enough fuel left in the filter to matter, compared to fuel that might get into the oil. Just use it!
California
:rolleyes: OK I got that out of the way laugh If you must reuse a filter, just wipe off the exterior and put it back on. Do not try to clean the insides, you will do much more harm than good.
Cali
Originally Posted by dwendt44
The 3614 Fram is $4 at Wal-mart. Their house brand, Supertech 3614 is $3. Just change it and forgetaboutit. My ¢
x2, duh
2K2AcuraTL
Ottawa, Ont CANADA
Interesting recommendation... just may try it... thx
2K2AcuraTL
Ottawa, Ont CANADA
thats what I thought as well on my first OCI ... wrong...!!... too much gas left in the filter.... brand new oil was immediately contaminated...
2K2AcuraTL
Ottawa, Ont CANADA
x2, duh
yah ok guys.. its only 3-4 bucks...maybe for you... we ALWAYS pay more for ordinary stuff up here... if I start throwing away good filters for nothing... it cut into me Scotch budget... wink LOL
NWA 60634
I'd save it. I hate wasting anything. Put it up on a shelf open side up with a coffee filter rubber banded over to let it breath and keep the dust out.
Parts Unknown
Originally Posted by danez_yoda
How does tht gas affect the rubber antibackflow valve. I'm sure it will shorten its life.
Agree, I would have tossed the filter for a new one.
