You see what one needs to understand is that the incessant sniveling about dome end bypass has as much (or likely more) to do with a foreign ownership agenda, as it does bypass location
After one has read this board for a while it easy to see the constant complaining about Purolator's ownership, makes the opinion regarding dome bypass extremely suspect by that member. Those who have read this board have seen that horse beaten dead, dug up, then buried only to be dug up again....
ad inifinitum!
Being as the Pure One is one the best, if not the best, bang for the buck, high quality, high efficiency oil filter's, it's difficult to find any negative. For those not familiar with the agenda....
ad inifinitum, of not liking Purolator's German ownership, it can be disguised by the bypass location contention. Nevermind the fact that Purolator oil filter are made in America.
As said here, while the thread end may be preferable, in truth, bypass location makes little difference in overall filtration and oil filter function.
So buy an oil filter that you are comfortable with, just don't be confused by the....
ad infinitum...
