Originally Posted By: Bruce T
Thanks, Gary, that's something else I didn't consider. Cold, thick oil would have greater trouble pushing through the rest of the engine than through the filter. Is your bypass test thread still posted on BITOG?
Yes, but unfortunately most of the images are gone from it. I was using Sony imagestion and they closed down. I scavenged a few of them, but without the links being intact, most of them really didn't mean much.
This is a shot (iirc) where the readings started to diverge on start up. The upper gauge heading to 82psi ..with the lower one hanging up at the lower level. Again, it was more or less a "transient" event in this engine. That's why I term "spinning tires" and such since it appeared that it was merely an expression of inertia where the fluid took time to get "in phase" with the power applied to it. The relief and the bypass (if you reached the proper differential) providing "slack"/cushion for an otherwise virtually solid fluid transmission.
Part of it
I then took out those individual gauges and tapped the lines into a differential pressure gauge. I was too lazy to run both. Actually I only had so much time to devote to the project and it was way easier to just swap lines. I had NO REACTION for so long with a brand new PureOne 3614 equivalent that I thought the thing was broken. I then placed a 9k used PH16 sized M1. Then in cold weather with heavy oil I got my reaction. It too was, more or less, transient in nature ...with extended residuals and effects due to the loading. Those images are lost.
The last test, iirc
I still have this setup (the lines and the welded shut sandwich adapter -remote mount), but it would be a pain to install in my jeep. The minivan had all kinds of room and had 180k on it ..so I could hack the thing and what did it matter. At least a pain for stuff that I already know, if you see what I mean
Here's how I tapped my pressure lines and temp sender (not in THIS image)
By
geeaea at 2007-11-20
