ZF Lifeguard 5
New York
Trans Pan Gasket Replacement.
Fluid is fairly new - Fresh Lifeguard 5 about 30 months ago.
Dropping the Pan is about 1/2 the fluid - 4-5L.
Anyone using Pentosin ATF 1 or just stick with the ZF FLuid
Maxlife is good stuff and will work in your ZF with no problem. Castrol Full Synthetic is also good stuff :)
The ZF Fluid is probably made by Pentosin anyway :unsure:
ancient stuff
i’ve used maxlife transmax and even generic dexmerc with no issues. the 19 and 24 don’t last past 150k anyway
I used Maxlife and serviced my ZF 5HP24 every 50-60k miles. It was running strong at 215k miles and that was with Dinan engine & transmission software. This transmission was very particular about exact and proper fluid level.
