C chefwong Joined Jul 17, 2003 Messages 909 Location New York Mar 20, 2021 #1 Trans Pan Gasket Replacement. Fluid is fairly new - Fresh Lifeguard 5 about 30 months ago. Dropping the Pan is about 1/2 the fluid - 4-5L. Anyone using Pentosin ATF 1 or just stick with the ZF FLuid
2 2EHA Joined Jan 18, 2020 Messages 2,594 Location United States Mar 20, 2021 #2 ancient stuff i’ve used maxlife transmax and even generic dexmerc with no issues. the 19 and 24 don’t last past 150k anyway
S slacktide_bitog Joined Mar 20, 2008 Messages 16,100 Location USA Mar 20, 2021 #3 Maxlife is good stuff and will work in your ZF with no problem. Castrol Full Synthetic is also good stuff The ZF Fluid is probably made by Pentosin anyway
N nicholas Joined Aug 20, 2003 Messages 2,147 Location ottawa Mar 20, 2021 #4 slacktide_bitog said: Maxlife is good stuff and will work in your ZF with no problem. Castrol Full Synthetic is also good stuff The ZF Fluid is probably made by Pentosin anyway Click to expand... Yes.....throw maxlife in there. No worries. Used it in an 09 audi 6 speed with zero issues
Egg_Head Joined Oct 7, 2012 Messages 1,311 Location North Carolina Mar 23, 2021 #5 2EHA said: ancient stuff i’ve used maxlife transmax and even generic dexmerc with no issues. the 19 and 24 don’t last past 150k anyway Click to expand... I used Maxlife and serviced my ZF 5HP24 every 50-60k miles. It was running strong at 215k miles and that was with Dinan engine & transmission software. This tranny was very particular about exact and proper fluid level.
