Originally Posted by rooflessVW
Originally Posted by dave1251
I used MAXLIFE ATF in my ZF-8 and thousands use it also. There is no reason to use ZF fluid it is nothing special.
Sure.
You prepared to replace his transmission if it fails based on your recommendation?
I wonder, do you have the same ZF8 as the OP? Are the internals the same? The programming?
Do you know anything your talking about? Do you know more then Valvoline. It's evident you don't so please continue.
The CTSC is a good source for parts and instructions when servicing ZF units. Definitely use the ZF pan, definitely use the ZF fluid.
Yep. Spend the extra $50 and get ZF fluid. Why do people always try to save money using non OEM ATF ????
I'm getting a 10 speed auto Camaro and when its time for ATF change it will be OEM and not MaxLife for my GM.
Different transmission different coefficients thus a different transmission fluid. Not applicable to this discussion.
Sure.
