I am bothered by the automatic transmission on my 2012 BMW 5. I bought the car used and although I serviced the transmission, I do not like the way it shifts.
When transmission is cold the 1-2-3 shifts make the car slow down and then lunge, they are not smooth. After a few miles of driving, the shifts are smooth, but only when in Drive mode. If I manually upshift, even at the same rpm as it's done automatically in the Drive mode the hard shift is felt again. And it's stronger as I shift at a higher rpm. 1st to 2nd gear has the hardest shifts. No errors present in INPA.
Has anyone been facing this issue?
