Maybe you guys can help. My 2012 bmw has a ZF 8 speed automatic with a torque converter. It's been having hard shifts since almost two years.
The initial symptom - very hard shifts from 1st to 2nd gear, especially when cold, but also when warm, sometimes - like being hit from behind.Other shifts noticeable.
I serviced the transmission one year ago (fluid drain & pan change) - fluid was not burnt and had no debris, used ZF Lifeguard 8 - a little better 1-2 shifts when cold, went better as it got warmer.
Then I added 1/4 gallon more fluid - apparently didn't have enough fluid, now it seems to be right level.
Currently: The shifts are harder in the morning - I can feel 1-2 gearshifts both at very slow and harder acceleration.
The sensation of the gear shift is a clutch is disengaging and the car picks a bit more speed (feels loose) and then it hits something which is slowing it down.
After around 10 miles of driving (with many shifts) and way after the transmission/engine have reached their operating temps, the 1-2 shift will get perfect under hard acceleration. It remains slightly perceptible under very slow acceleration (a gentle push from behind).
There is also a vibration/bump when braking almost to a complete stop - like the transmission is grappling onto something which slows down the car more than I'm braking, then lets go.
The haven't been any error codes from the transmission, never and no other problems.
What I find very surprising is that it seems to shift better if I stop the car for around 30 minutes and also if I drove a lot in the morning (to the point of shifting good) and I park it 8 hours (50deg F outside) it will still shift good although the fluids must be cold again. But if I leave the car overnight the bad shifts return.
What do you guys think?
