Okay, Not horribly high mileage.
Wouldn't be a bad idea to try a TCC Solenoid & a Sonnax drop-in TCC Regulator Valve.
The TCC itself do fail, Quite a bit more frequently than 4L60E units of the same years at least in part because the calibration.
Anytime the TPS is below 5% throttle angle....4L80's cancel lock-up. So if you drive say 300 miles, Every time you let off the throttle, The converter unlocks....Them "PWM's" back into lock-up, Depending on one's driving habits.....The TCC could've experienced a 1000 on/off cycles.
There IS a reason it's calibrated that way, Let's say you're fully loaded to GCWR & headed down a long grade At zero/closed throttle.....You only have 60-70 PSI available to keep the TCC locked.
Have you dropped the pan?
