So the number one failure is that one lifter either stops spinning or spins slowly and scores the cam. Yes, Comp Cams has had a batch or two of soft core cams. Yes, they have mostly all been using off-shore lifters.
Add the two together and it's cam failure time ... Look very carefully at the lifter faces. If they are scored or cupped, it was lifter failure that took out the cams. Lifters are supposed to be very hard. Good ones can resist a lot. bad ones go easy and first.
So I either use Crower Cam-Saver or Howards Direct Lube lifters (both made by Johnson) for all my flat tappet builds. The solids can be had with EDM oiling holes. The hydraulics have bleed slots on the outside. But either style will supply extra oil to the lobes.
Many an Aussie engine builder has been re-using older OEM lifters that they re-grind the convex face on. Problem is there are few USA machine shops that will re-grind older OEM lifters. The Aussies do it because new USA OEM lifters were just too pricey. Then they found out they didn't need to, so they have an industry in place.
The issue is the face hardness. Modern replacement lifters are pretty much junk. Crower publishes the face hardness and radii specs for their lifters. Howards has a 5-year no question asked cam and lifter guarantee if you buy as a set and break them as they direct in the instructions. They both perform extremely well.
I feel comfortable mixing and matching Crower and say Crane cams. But, unless you've been doing this for a while, you have to be extremely careful. There are a lot of good engine shops that will build a killer engine and then depend on the cam mfg to supply the valve train. If comp, it often does not work out ... Sorry, but that's the way it is.
Rule one, use Crane Cam Lube (black paste). Nothing else during cam assembly.
Rule two, have the carb primed, timing set and the oiling system primed so that it's nearly instant fire. No extra cold cranking to get fuel or any of that kid stuff ...
Rule three, have the valve covers loose when you light the motor. Pull them quick and make sure all the push rods are spinning freely. If one is slow or start/stop, kill the motor and find out why immediately ...
Yeah I know running with oil flying is messy, but loosing an engine is messier ... As soon as you are sure everything is spinning right, shut the motor. Button down the valve covers, and re-fire. Go back up to 1,800~2,200 and vary slightly for 10 minutes at least. The longer the better, up to 1/2 hour.
Rule four, make sure all the oil system by-passes are blocked and inoperable. Use hydraulic system type filter w/o internal by-pass. Use oversize, easily available for both those motors. The reason for this is if any cam/lifter metal gets loose, it can not get past a filter unless tossed by the spinning crank. At least it will not get through the oil passages to embed in bearings. That will save you a lot of re-machine work if things go south ...
Even though there are soft cores out there in inventory, some cam companies never bought into the parts stream that ended up with these. Crane, Crower and Howards have been rock solid. Lunati has been pretty good. Comp has not ... GMPP has had some soft cams too ...
