YUGO is coming back!
edyvw
$50 site donor 2025
Colorado Springs, CO
The proof of the pudding.....gotta wait until 2027 for the unveiling.
They can do it right or they can do it wrong.
I'd be nice if there was a time line online.
This happened years and years ago, a Yugo was traveling across the Mackinac bridge , that bridge separates the upper and lower peninsula of Michigan . Tip to tail the bridge is 5 miles long, and it is high in order for freighters to get under it . Four lanes wide, two center lanes are a iron grid . A gust of wind came and picked the Yugo up and fell 200 ft to the water .
Yugo was light (an understatement). I have seen serious vehicles being picked up by wind here in CO.
This YUGO must have modern platform and engines to be sold in EU. So, weight will be definitely on par modern vehicles of that size.
Opening the door for a potential new model is Dr Alekasandar Bjelić, a university professor who has secured the naming rights. Indeed, he has already recruited Serbian designer Darko Marčeta, who has penned what a future Yugo could look like.
Naming rights and a poorly-drawn concept pic that's trying too hard to look like the original car to try to give it some kind of legitimacy, and that's it. The definition of vaporware.
/wetblanket
https://en.wikipedia.org/wiki/Mackinac_Bridge
On September 22, 1989, Leslie Ann Pluhar died when her car, a 1987 Yugo, plunged over the 36-inch-high (91 cm) railing. High winds were initially blamed, which was not supported by recorded wind speed measurements taken on and around the bridge at the time of the accident. Later investigation showed the driver lost control due to excessive speed and her vehicle bumped the bridge's 4-inch-high median and then crossed back through the northbound lanes, hitting a curb, jumping an outer guardrail and falling off the bridge.
Bet it will be a rebranded mitsubishi mirage with a boxier body and I have zero problem with that. It's a great reliable and simple little car. Cvt lasts forever if you take the 5 minutes needed to do spill and fills. Has a normal single drain bolt and trans dip stick.
