You've gotta love these guys scientific method.
Australia
From BGMOA : http://www.bgprod.com/products/engineoil.html
Quote:
At the conclusion of the API Sequence IIIF Engine Test‚ a major brand, high-quality reference oil barely passed the 80-hour test with a viscosity increase of 255 percent. At 80 hours, another brand of oil fortified with BG MOA® had a viscosity increase of only 57 percent.
Huh. Why wouldn't they test the benefits with/without on the same oil? Unless they had something to hide.
Pretty poor experimental design. What do you want to bet that the improvement was due to the different oil, rather than the BG MOA?
Yeah you've got to wonder why they even bothered with that comparison, two different base oils.
What I find most disturbing is that they feel it's not a big deal to have that spelled out on their website. That doesn't speak highly of how they perceive the folks who will be reading it...
I suspect they are trying to tell you that using their additive you can use cheaper oil and still have better performance than just using the expensive oil.
If they said same oil and the numbers went from 255 to 57 that may add some credibility.
We don't even know what number the other oil had without their product.
I don't see how one could come to the conclusion or even suspect they mean you can use a cheaper oil and get better performance than an expensive oil from this statement.
Its just not there even between the lines.
For all we know the..
Could be just a major brand dino and the other oil could be a high end GpIV/V exotic that had a number of 25 before they put their snot in it.
Only BG know for sure.
The other thing I noticed when I just read their claim is that they are still stating the results were achieved using two "SL" oils. I am not saying there is anything wrong with SL but the tests results would not be valid just due to out of date specs if not for the other glaring problems.
