Consider wheel bearings, transmission, etc.... The rest of the car besides the engine.
What exactly are you going to consider? Your wheel bearings are going to be driven
COLD when you drive in a
COLD climate. There is nothing you can do about it. Friction and dissipating brake heat will warm them slightly, but you have to drive the vehicle for that to happen.
Driving over potholes and railroad tracks in sub zero weather is going to cause shock absorbers to leak, because the seals are hard and brittle. And the fluid inside them is thick. There is no way to warm them up either.
The transmission, engine, along with everything else will warm up
faster if the vehicle is being driven, not sitting and idling. Start the engine, wait for sufficient oil pressure, (2 or 3 minutes), and get underway
slowly.
In below zero Winter temperatures you are going to have more leaks, period. Radiators, water pumps, heater cores, thermostat housings, etc. Having an engine constantly going from below zero, to over the boiling point, then back down to a block of ice several times a day, is going to cause constant thermal expansion and contraction. That will generate more leaks over time, than a car that resides in a constant warm or hot climate.
And to frost the cake and light the candles, you are most likely going to be dealing with road salt that is going to corrode and rust your car, regardless of how you baby it in cold weather.
Years of driving in Midwest Winters proved to me, that regardless of
what you do, your vehicle is going to have a limited life, when compared to one being driven in a hot and dry climate. The only solution is to move. Ask me how I know.
