That's interesting. My attached garage is fully finished with drywall and about 700 square feet. The door faces south and the sun really beats down on the door in the summer months where outside temps often get up in the high 80's. A couple of years ago I installed those Styrofoam insulating panels on the roll-up aluminum door from a kit I bought at Lowes. In the winter months the garage now stays between about 50-58 degrees on average even when it is in the 20's and 30's outside. However the insulating panels are less effective in the summer, probably due to the amount of direct sun that the door receives. They still cut at least 10 degrees as I can feel a lot less heat radiating on the inside of the door now.We don't get as cold as Minnesota but sub-zero temperatures (not "wind chill" either) are normal every winter. Definitely no heated garage here and I don't think they're common at all unless someone has converted their garage or uses it as a "shop". Anyway, I added those insulation panels to our garage door a couple years ago and took some measurements. Needless to say, they don't help in the winter but do help in the summer (door faces west). Here's some measurements I took:
26º F outside temperature | 23º F
49º F center of floor | 46º F
39º F center of door | 45º F
48º F center of ceiling | 47º F
I guess they actually worked on the door itself. It was colder outside after so my second readings were lower as well.
Just re-checked the temperature forecast and the high temperature tomorrow is supposed to be 1º FThat's in the middle of the day.... At 9am tomorrow, the temperature is expected to be -6º F.
We get a little snow here, I'm up at 6000 feet but the county puts sand on the roads instead of salt so that is not an issue. I just have to sweep the garage floor about once a week to get rid of the sand and gravel that accumulates.
