If Firestone says don't do it, I'm seriously considering doing it. They have long been the least trustworthy shops around.
I didn't read the article. I might guess you are discussing wind chill.Totally irrelevant to objects. Only affects us and the rate of cooling.
My guess, cars are now starting reliably in the cold temps. Hit the key and it's running. Thin oils, better starters and EFI. No worries about not starting, in ye olden bad days, that was a legitimate fear.I don't understand why engine block heaters aren't more popular in areas that get cold winters.
Which means the car thinks it is -18. RealFeel(r) is wind chill - what happens to a warm human. The car cools to -18, and then stays there.
My wife's 2014 Fusion has one (never used it - car is parked in garage). Ford automatically adds these to vehicles originally delivered to certain northern US states as well as most or all Canadian provinces.Are block heaters incompatible with today's modern engines?
Yes, modern tech and easier starting. You definitely still see them here, although becoming less common. Most of us have heated garages so it's a moot point. In my case if I had one I would never use it due to a warm garage in the morning and not having a place to plug it in at work.My guess, cars are now starting reliably in the cold temps. Hit the key and it's running. Thin oils, better starters and EFI. No worries about not starting, in ye olden bad days, that was a legitimate fear.
A block heater would have to be plugged in. This generation couldn't get by without automatic wipers, automatic headlights, blind spot monitors and automatic braking, along with lane assist and wireless connectivity with their phone. Plug in a block heater every night, only to have to unplug in the morning? What a nutty idea.
Most people have heated garages where you live? That's interesting. I know a lot of people in Minnesota, but can only think of one with a heated garage.Yes, modern tech and easier starting. You definitely still see them here, although becoming less common. Most of us have heated garages so it's a moot point. In my case if I had one I would never use it due to a warm garage in the morning and not having a place to plug it in at work.
"Most of us have heated garages" not so much where I live. Usually the attached garage is a bit warmer that ambient but rarely heated. Shops tend to be heated but not many guys park the DD in the shop just for the mess they would bring in and cars would rust significantly faster here if they were kept at 50F every night.Yes, modern tech and easier starting. You definitely still see them here, although becoming less common. Most of us have heated garages so it's a moot point. In my case if I had one I would never use it due to a warm garage in the morning and not having a place to plug it in at work.
Not sure about there but my attached garage only rarely hits freezing in winter. I'm 99% sure the interior wall is properly insulated, but have to figure, whatever heat leaks through it goes into a garage that has its own insulation, so some portion of that is caught. Park a hot car in every night and again, some heat transfer.Most people have heated garages where you live? That's interesting. I know a lot of people in Minnesota, but can only think of one with a heated garage.
It is, but I would not be surprised that a vehicle which is driven will generate the same about of cabin heat in the same runtime as one which is idled and then driven. Even today with so many cars having electric heaters/seats to help take off the chill it seems rather silly to let a vehicle idle just to warm the interior.I'm sure some of it is an attempt to cut down on emissions from people idling their cars in their driveway to warm up.
We don't get as cold as Minnesota but sub-zero temperatures (not "wind chill" either) are normal every winter. Definitely no heated garage here and I don't think they're common at all unless someone has converted their garage or uses it as a "shop". Anyway, I added those insulation panels to our garage door a couple years ago and took some measurements. Needless to say, they don't help in the winter but do help in the summer (door faces west). Here's some measurements I took:Most people have heated garages where you live? That's interesting. I know a lot of people in Minnesota, but can only think of one with a heated garage.
Same here; my garage is detached and unheated but the two cars I keep in it will be there until March. I hate the "sand dunes" of finely powdered salt that gets left behind in the garage when cars drip messy, salty slush on the floor. So the daily drivers sit outside where if nothing else the rain eventually washes away most of the salt."Most of us have heated garages" not so much where I live. Usually the attached garage is a bit warmer that ambient but rarely heated. Shops tend to be heated but not many guys park the DD in the shop just for the mess they would bring in and cars would rust significantly faster here if they were kept at 50F every night.
If you ever heard a vehicle start up at minus 30c, you'd probably understand. You wouldn't be throwing it in gear and pulling out immediately.How does your car know if it's being "warmed up" by running, or by driving? Or how much of each or either? Running is running, and temperature is temperature. Regardless if it's Orlando in July, or Fairbanks in January.
Really old and homes on the low end of the price spectrum no, but for the most part your typical descent house with an attached garage, yes. Some are insulated only, and only few are uninsulated. Most commonly you'll have NG overhead blowers (like mine) or newer construction you will find radiant slabs that utilize the home's main NG tankless water heater.Most people have heated garages where you live? That's interesting. I know a lot of people in Minnesota, but can only think of one with a heated garage.
