XG4386 Replacement
Does anyone make an oil filter to replace XG4386 with a 99% at 20 microns? Can't seem to find these available anywhere from fram anymore, they suggest using the smaller size XG4967. I would like to keep the larger size and the XG3600 won't fit in my application. Purolator and Wix make them, but they don't have the same efficiency.
Pentius makes a PLXL4386 than I’m using on my whole house generator. You can also use an STP Extended Life S3600XL or a PG195EX. Both of those are about 4” long.
  • Like
Reactions: GW.
Ended up going with the PLXL 4386, many of the other filters had language like filters 99% of contaminates down to 20 microns, but didn't state their efficiency at that specific micron rating. The pentius states it outright. Plus it's cheap and has a silicone ADBV and gasket. Thanks all for your suggestions!
