Ugly3 is correct here. millerl, look at the Oil Pump Overhaul diagram, you'll see the typical relief spring valve assembly. It is designed to begin to open at set pressure and limit maximum pressure.quote:
Originally posted by Ugly3:
millerl - I sincerely hope I didn't take anything "out of context" in my earlier remarks.
I think you have. I see nothing in the specs that addresses the oil pump releif valve settings. All the specs are "min" values not "max" values.
You are supposed to get a min of 10 PSI at normal temps at idle. At 3,000 RPM you are supposed to get a min of 44 PSI. Certainly could be higher, particularly when the engine is cold.
The pump flow data suggests that at 3000 RPM your pump output will be approximatly 7 Gallons per minute. At 6000 RPM the flow could be 14 gallons per minute if the oil pump releif valve allowed the oil pressure to reach 88 PSI.
At 6000 RPM at normal operating temps what does the oil pressure gauge read? That will tell you how close to a 14 gallon per minute flow rate you are running.
You have data you haven't shared with us?quote:
Originally posted by Gary Allan:
For example, I've got a 20 x 2" 1um filter plumbed on my Caravan. If I did my figures right, I've got 125 square inches of media at a 1um nominal. It has a 1 square inch center tube. That means that it goes from 125 sq" of media down to about 63 sq" of media. Much smaller/lower than our pleated medias of far less restrictive material. With 20 weight oil, I see 2 PSID ..all the time. It starts out @ 82 psi and drops to as low as 22 psi (32 typical). If I use heavier weights ..I may go to a 4 PSID. In this case the filter is a non-issue.
I think I have everything all ready. I've got the adapter for the filter mount ...hmmm..but I only have dual remote mounts. It might be hard to find 3/4-16 thread filters w/o a bypass ..but plumbing the tees for PSID readings will be a snap. I've got just about every fitting known to modern man. I've got both Ford (3/4-16) and Chevy (13/16) dual mounts ..but I don't know if they make the Chevy in a single. That would give us a no-bypass filter sure enough.quote:
Now if we can just talk you into repeating the experiment with a normal full flow filter without a bypass valve.I'll chip in for any expenses it requires.![]()
I'm confused by this part. This remote mount has a bypass valve? Or is it the sandwich that has the bypass valve? Or neither? Why did you drill two holes in the Permacool mount and where did the holes start and end? Is the new sandwich strictly to allow a remote filter installation, i.e., it just directs all the flow to an inlet/outlet ports you attached lines to?quote:
Yes ...or so I reason. There is the poppet relief in the Permacool ..but if it was modulating ..you would hear buzzing and the gauges should be bouncing. I don't see any ocillation from the gauges. When I first installed it ...I doubted Ralph's assertion that no mods were required to the PermaCool. I drilled two 13/64 holes in the permacool. After warm up ..I had a cold filter. Those two holes didn't provide enough differential to push anything through the filter. I installed a new sandwich ..no holes ..worked great with only 2 PSID.
This is interesting. When you add up all the area provided by the bearing clearances in something like a Honda V6 you get ~.5 in^2 not including the VTEC system, and all those bearings you claim can be supplied by ~.02 in^2 of area provided by your two 7/64 holes.quote:
That means that the entire engine, after warmup, could be totally supplied with all its lubrication needs with two 7/64th holes for a supply.
Yes, they do:quote:
...I don't know if they make the Chevy in a single [mount]...
I'm not sure this alone is a valid assumption. Unless the bypass valve/spring assembly had absolutely NO damping, I wouldn't expect it to "buzz" like that.quote:
If this was opening ..it would modulate rapidly (buzzing) as it evidenced the shockwaves of having too dense a media and suddenly having that resistance released. If it was open ..then I would most likely see gauge fluctuations (bouncing needles). I don't.
andquote:
This is interesting. When you add up all the area provided by the bearing clearances in something like a Honda V6 you get ~.5 in^2 not including the VTEC system, and all those bearings you claim can be supplied by ~.02 in^2 of area provided by your two 7/64 holes.![]()
You think it didn't shock the heck out of me ???quote:
I am going to have to think on this one for a long time. All the oil need through 2 7/64" holes - hard to get a grip on.
Beats the crap outta mequote:
What is the output rate of your oil pump and what oil pressure do you run at say 3000 RPM? Trying to guesstimate the GPM of oil flow.
Okay ..so they approach getting the um rating a couple of ways (at the same time). Varied diameter of the string ..and tension when being spooled/spun. Interesting. I can't wait to use the 3.5" 1um filters. I've still got mileage left (a good bit it looks like) on the 2.5" that I have thoughquote:
Gary..The string has a certain diameter, and the tighter the wind, the lower the micron rating. That's how string wound filters come up with their ratings.
It has in certain installations ...look here click mequote:
I'm still confused. Your setup allows another path for the oil to flow from the oil pump to the engine besides the 1um filter, namely these two 7/64 holes?quote:
I installed it with the two holes ..felt it warm up in a short time at idle..patted myself on the back and did a little jig. Drove to get fuel (there's a big price dip over the county line that made the 8 mile trip worth it) ..got out ..popped the hood ...stone cold. As the viscosity approached operating thickness ..it was easier for the oil to just increase in velocity going through the two small holes than it was to make the trip through the 1um filter.
Okay ..quote:
The startup pressure is 82/80 via the gauges that you see in the above image. After initial warmup ..this drops to about 38/36 (as you see). If idled long enough ..it may drop into the 20's.quote:
