Worn CV Shaft
Illinois
Can a worn CV shaft cause vibration felt in the floor? When I get up to 70 MPH it becomes noticeable and just a little more pronounced at 75 and up. I've had the tires and wheels checked and they are all fine.
Still could be tires and wheels - many shops are incompetent.
What Vehicle?
Give some specifics!
You should be able to do low speed reversing at full lock and find the bad actor.
Jab the throttle a bit when reversing with the wheels turned all the way
Bad axle should click or clack. Might help haveing an assitant.
Dont run them over though!
98 olds 88. The tire shop road force tested with the new tires on and all wheels and tires are fine. Which draws my attention to the CV shaft. I say that because I replaced one CV shaft on the right side but not the drivers side
