7th Gen (2014) Camry RH CV Axle Reboot
northern Alabama
Looking to rebuild the passenger (RH) CV axle on a 2014 Camry SE 2.5L 4 cylinder (2AR-FE) with 6-speed U760E AT. It has ~ 250k miles with a leaking boot. The right rebuild kit (p/n 04427-0R104) and axle nut (p/n 90080-17238) were $40 after the recent Toyota 25% additional discount & free shipping (with $75). A 30mm 12-point socket appears necessary to remove the axle nut. I've replaced CV joints so understand that when removing the joint but won't come out then rotate axle 1/4 turn & try again. However, I've not rebooted one. But in any case I don't plan on removing from the transmission but rather plan to remove the IB boot clamp & remove the CV joint from the vehicle without disturbing carrier bearing or bracket. I understand there is a chance the spider has been damaged (water intrusion - rust, etc.) & the repair will need to be aborted & just replace the CV joint. I've watched the below video for guidance.
TOYOTA OWNERS! Never Replace Your Leaky Axle | Fix Them Instead! by Car Care Nut
What boot drive shaft clamping tool should I use? The Toyota p/n 09521-24010 can be found on ebay for $109 from Spice Japan or $116 from Good Life Your Life or $133 from JP Motors. Any thoughts on those sources or other source options? Or scrap the OEM tool and use an aftermarket tool? I'm not aware of this tool being available as a loaner tool from various parts stores.
Are there any other tips/tricks/items to be aware of? It appears the inner boot gets the thicker & darker grease in the Toyota kit.
Thanks.
Unless you're gonna do this professionally the aftermarket copies of the tool for $20 should be fine.
I have this one. Not saying it's good or bad. I think I've used it once and it was "fine"
https://www.amazon.com/dp/B0CRR33549
Honestly for tight quarters this 90* plier is my preference if it'll work.
https://www.jbtools.com/lisle-30600-cv-boot-clamp-pliers/
Are the clamps definitely all Oetiker style crimp-to-close? An image of your part # shows two possible styles? Maybe just a stock photo?
Regardless I'd highly recommend just getting a set of these for earless. Inexpensive but difficult to find in a pinch (pun?)
https://www.amazon.com/Lisle-30500-Boot-Clamp-Plier/dp/B0002SREB8
Finally, even with a lift standing under a vehicle, trying to rebuild a CV on the vehicle sounds like less fun than a root canal. Personally I'll fight to get it on the bench.
Post pics of progress and good luck!
It looks like this one uses a jack shaft on the right side, I cant say if the jack shaft is removable or not (I would think so but I don't work on Toyota), it also uses a carrier which you may need to remove. Best case the CV pulls out of the jack shaft with the help of a prying tool or wedge tool or you need to pull the whole thing out. No need to remove the transmission, it does use Oetiker clamps, I use these but the ones D60 posted will do the same job.
Lisle 30800 Cv Boot Clamp Pliers
You should also have a straight set like Trav posted, but I figured that was a given. The 90* is only for tight quarters, which is also where Toyota's vise style can excel -- although it's still far more bulky than the 90* pliers.
If you're ever stuck any pair of flush cutters will work as a straight tool for Oetiker. Just sand the cutting edges a bit to dull them. Pros: readily available at hardware stores and even ag/Co-ops. I have a set deliberately because the handles are longer than any automotive-specific. Some larger Oetikers on CVs can benefit from the extra leverage to get them tight.
Basically you need 4 to 5 tools to handle 98% of CV clamps, but with careful shopping they can all cost less than the $113 Toyota OEM
Oh also the "tight quarters" I mention are usually steering rack bellows. Replace inner TREs like a champ!
I try to have all CVs on the bench, but obviously getting a steering rack on the bench is impractical and unnecessary to replace a bellow.
I can send you the tools as a loaner. Do you have an air hammer? The bearing can be difficult to dislodge from the bracket but getting the axle out of the knuckle can be equally challenging.
You can certainly leave the inboard end in the vehicle but it is a messy and annoying way to do the job....unless you have no other choice.
Also, removing the snap ring on the tripod can be difficult. Some of those tripods also need a lot of persuasion to come off the shaft.
  • Like
Reactions: D60
To clarify, I plan to remove the CV joint & do the reboot on the bench (vice) by cutting the IB clamp while in vehicle & then pulling out. That way I don't have to remove the bearing or bracket.
What tools do you have?
I'm in Alabama so am hoping getting the axle out of the hub will not be difficult.
I do not have an air hammer. I have hammers and hot air though!
Messy and annoying (reboot) sounded better than paying for a new axle, bearing, & bracket. This statement may not age well.
But the snap ring comes right out in the videos! Just kidding. Yeah, getting the tripod off the shaft may be a fight too. Everything may be a fight! I guess I'm trading the fight of the carrier bearing with removing the tripod.
  • Like
Reactions: D60
@The Critic, @Trav, @D60 & anyone else that can offer good advice.
Started work on this today, & I'm not winning. That's what I get for pretending to be a mechanic! Anyway, the axle pushed back in easily through the hub once the axle nut was removed (let's not talk about that activity as I have to use a replacement axle now). Removed the (3) 17mm nuts/bolt from the ball joint flange & moved it out of the way. But when I turned the knuckle out of the way to retract the axle out of the knuckle, evidently I wasn't careful enough, & the shaft disconnected from the inner & won't go back in(?). How do I get the axle out of the knuckle now? The axle sticks out several inches from the knuckle. See pictures below. Do I have to cut the axle in half? Surely not...
Just take the axle out. Insert pry bar between inner cup and the bracket, have someone rattle the bearing bracket using a flat tip on the air hammer.
If it's already come apart, don't be afraid to keep pushing it back. If it doesn't go, rotate/try/rotate/try repeat
I'm guessing that's a tripod joint and we're gonna hope all three bearings are retained with a small snap ring so they can't just fall apart in the boot.
@Trav or @The Critic might know the answer to that ^
@The Critic Will that require that I remove the bearing bracket too so it will all come out together then? The snap ring at the bearing came out easily on the vehicle. I thought that it had to come out of the knuckle first before removing from the transmission.
No, there’s a bearing that sits on the shaft. The bracket stays on the engine.
  • Like
Reactions: D60
As for the outer end of the axle that’s still in the knuckle, reinstall the axle nut and use an air hammer to push it out.
Try jacking the wheel slightly to get the axle straight then wiggle it back into the tripod joint or cut the tripod end boot clamp off and pull that end down then push it out from the wheel side.
Got the axle out of the knuckle by rotating/pushing/rotating until it pushed back in. Thanks guys. I had the same issue on a '94 Grand Am on the transmission end of the CV joint that wouldn't come out & had forgotten about the simple thing of rotating it. Good grief. But it's out & that's what matters now. Will work on it more later this weekend.
