Originally Posted By: Thax
No it does not , however using any filter that is not a end bypass design will cause it to have startup noise. Example tried a few Purolator classics before the "tearolator" scare a few years ago and it rattled a little bit. I will use the Wix or Mopar filter to prevent this.
OK, which end of the filter do you consider the end ? The NAPA Platinum I got ready to put on has a dome end bypass. The NAPA Gold and the regular WIX have an inlet end bypass.
