This is why I use this exact filter on both the Dodge and Jeep , cannot beat it for value.
Does it cause a startup noise on your 1999 Jeep Cherokee? I noticed your Jeep and dlundblad's Jeep both have the 4.0L straight six.
No it does not , however using any filter that is not a end bypass design will cause it to have startup noise. Example tried a few Purolator classics before the "tearolator" scare a few years ago and it rattled a little bit. I will use the Wix or Mopar filter to prevent this.
I have had very good luck with the Mopar filter which is also the end bypass, but I was unimpressed with the quality when I cut one open. I believe Fram uses a dome end bypass which doesn't seem to cause any issues for me (yet). I used the Mobil 1 filters for a while and experienced the same start up noise with them as well. They are quality filters no doubt.. they just don't work well with my application.
Mopar cut open. 5000 miles Pennzoil conventional.
On a side note, my dad uses Mobil 1 filters on his Renix 4.0 with no start up chatter whatsoever. He ordered 1 from Oreillys (different thread pattern than the 51085, Mo-90, etc) and they gave him a case of 12.. The clerk even said it was their mistake and still gave him 12 for the price of 1. He is set for a while so there is no going back. Lol.
