I recently set up a NETGEAR 54 Mbps wireless router (model WRG614, 2.4 GHz, 802.11) with my cable internet service modem. For the first day or two the speed was great and consistent, then it began to periodically fade out. Now the speed goes up and down numerous times each day, and when it is slow it is virtually useless, often timing out. The router is less than 10 feet from the computer and in direct sight with no obstacles.
If I shut off the router, or log-off and then log-on again, the speed jumps right up to 54 Mbps. This could last for an hour or, more often, only minutes before the speed drops again, and continues to go up and down. My computer always says the signal strength is excellent, but it does show the speed varying, usually between 54 and 24 Mbps and sometimes lower.
If I disconnect the router and feed the modem directly into my laptop through the same cable that connects into the router, the speed is high and stays high 95% of the time (there is some occasional delay but not often.)
Is this router defective (it is several years old) or could I have done sometime wrong? Could the LCD TV, which is on the same input cable via a splitter, be interfering? The problem does persist even when the TV is off.
Thanks!
Tom NJ
Thanks!
Tom NJ
