Originally Posted By: buster
Originally Posted By: JHZR2
Winter tires are run all year round in the Caribbean, where steep wet hills demand traction. It just works for them, and has worked for a long time. My mil even has a set on her Camry now.
Is it absolute best? Don't know. But probably gives better wear than a summer performance tire on a non-performance car in a place where you can't drive fast anyway.
Different than the US, but many do with success.
Good to know. I'm asking because the 03 Forester I picked up came with new Michelin Ice X tires (I forget which ones specifically) and I don't want to change them out right now. I will be taking this car on the beach so maybe having these tires is a good thing. I did read that winter tires can be great on dirt/gravel type roads.
I think your answer may depend on how much tread remains on the tires. Most winter tires have the first 50% or so as a "winter" compound and the remaining tread is an all-season compound. If they are worn past the snow wear bars, they should funcion as an all-season tire with a bit more siping.
I'm currently running my Hankook W300s all summer because two reached the snow bars and the other two are almost to the regular bars. They actually perform quite well, as good as the set of Eagle GTs that I had installed new last fall and drove on for 6k miles before winter. They are a bit noisier than the Eagles, though but that doesn't matter to me much as it's just a commuter car now.
