Wind deflector placement on '19 Pilot for small enclosed trailer.
Long Island, NY
I towed the trailer below with my Pilot to Virginia and back. No real heavy load, trailer is 840lbs empty, max 500 lbs in it for the trip. For the 8 hours each way the Pilot did not want to go to 6th gear and that was doing 60-65mph. There was definitely a large wind drag from front of trailer. Understandably it's not the most aerodynamic brick of a front. Monitoring transmission temperatures also showed 65mph was about it or temperature started climbing a bunch more even with factory transmission cooler and still in 5th gear.
I was thinking on the drive from NY to VA that it needs something to help get the air over the front easier. The Pilot roof slopes down some in the rear so I think just make it flow right into the front of trailer more.
What would be a better placement of a wind deflector on Pilot the front or rear crossbar? The cross bars on Pilot are not adjustable so what you see in picture is it. Over the back door or over the cargo area. I'm thinking further back to get the air moving up without as much chance to drop down.
I just picked up an INNO wind deflector locally for $40 like the Yakima / Thule versions. I want to try it next time I plan to haul longer distance. It just clamps on pretty easy so I could try rear one way, front the other way. Maybe it won't help do anything, who knows?
