Will Thinner Oils Damage Your Engine?
You'd have to spend some time searching, but an old member here Gary Allan (RIP my friend) conducted tests running a custom blend 0W10, made by another member here (I believe they called it BruceBlend), in his Jeep Wrangler's 2.5L 4 cylinder.
Jeep 2.5/4.0/258 engines are known for leaving a little iron and if memory serves, the UOA's weren't too bad.
Manufacturers have to meet CAFE regulations in the USA. If that means increasing the warranty period by 50% but specifying a lower viscosity oil than they would in another country they'll just do that. So IME when your car is about 7+ years old you should research potential possible alternatives (like what they run in other countries) and also what the actual reliabiliy data has been. My RX-8 specs 5W-20, and that is NOT a good choice for longevity. Keep in mind if your motor uses a lot of oil in a hydraulic manner in its design to run for example VVTi (the 1.3L Mazda rotary does not apply), be careful about deviating without being very sure of your research.
You want a higher HTHS oil? Then get one with an approval that requires the HTHS you are seeking.
Per SAE, 0W-40, 5W-40 & 10W-40 grades and 5w30 all have a HTHS minimum of 2.9. its easier if they just list the **** HTHS visc rather than navigate the spiderwebs of ACEA specs. I don't drive European cars, so I'm not familiar with their laundry list of specs. I want to use the thinnest visc with my desired HTHS. For that, I'm using M1 ESP 5w30 going forward.
Anyone remember former BITOG member Dr. T? He would run a 20w50 in everything. :LOL:
BuickGN and I were always proponents of thicker oil.
I think he was banned..
I haven't seen BuickGN around here in a long time. He actually did engine tear downs. He definitely knew what he was talking about.
I've always been a "thickie" as well.
If I remember correctly, someone here many years ago tried running 0W20 in a (I think) 10W40/20W50 spec engine and it grenaded shortly thereafter.
I switched from a 10w-30 to 20w-50 in a 302ci SBF and sent the #2 piston into the oil pan while rod exited the block and was found 60ft away. The 380 hp shot of nitrous I was spraying through it certainly had nothing to do with it. :unsure:
That changed, FYI.
My 2013 Toyota 2.5 2arfe calls for 0w20 and I'm using 5w30. The manual says a higher viscosity may be used if driven in extreme conditions but they do not define extreme conditions. Also I believe the same engine calls for a range of 0w20 to 5w40 in other countries
xW-30 replaces xW-20 in my stuff calling out (CAFE driven) xW-20. More MOFT and HTHS viscosity for better parts separation and less long term wear. All the same engines used in other countries (like mentioned above) that call out a big range of viscosity above xW-20 tells a lot.
