And THAT gets to the crux of the answer.No manufacturer that produces high performance engines recommend 0W20 in their engines.
Of course not. It's a high performance engine. No manufacturer that produces high performance engines recommend 0W20 in their engines.
It’s always so entertaining when a new guy shows up with articles and graphs and tries to teach established experts a thing or two.
Extreme cold is one of the reasons why synthetic lubricants originated (the others were extreme heat and lack of crude oil).That's interesting. Two winters ago, I ran a certain Castrol 5W-30 in Wisconsin's -20 degree weather and found it performed terribly. As much as I like the oil in warmer weather, it didn't impress me in the cold.
I switched to QSUD and Rotella GT for wintertime ops, becoming satisfied with their performance.
I think the answer is, who really knows for sure. How many people keep their vehicle long enough to experience any engine mechanical problems?
Many people on this forum have stated that their particular vehicle has over 300K running a quality 5W-20 with no issues. Is this because of a great engine design that has nothing to do with oil viscosity or that 5W20 protects the engine adequately?
My 14 Mustang GT calls for 5W-20 and is what I currently run in it. Other versions of this car that are more track oriented spec 5W-50. Obviously I could probably run either viscosity or anything in between and be good. If I don't track my car or run it hard, will these higher viscosity oils make the engine last longer? I have not seen any evidence anywhere that it will.
Agree! Bottom line, if your vehicle is spec'd for xW20, use a good quality synthetic xW20 and don't worry about engine damage. It's been nearly 20 years since 5W20 was introduced. Probably going to take another 20 years for old folks (or they will be dead by then) to accept that a full synthetic xW20 will not damage your engine if it is spec'd to run xW20. I reiterate FULL SYNTHETIC. Not that BS synthetic blend.
They do not plan on keeping the engines until next year's models come out.NASCAR engines run lower than 0W20 viscosity oils.
Unless you tow a trailer, drive in extreme heat, beat the engine, drive at very high speeds, in which case you may want to up it to an XW-30 or even an XW-40.... if your vehicle is spec'd for xW20, use a good quality synthetic xW20 and don't worry about engine damage.
Interesting, do you know which engines?Ford also changed the spec back to 5w30 on some of their engines calling for 5w20 to reduce warranty claims years ago. I read that here a few years back, it caused some interesting replies and debate, and some name calling as well.
Is this quantifiable? (no damage part) or based on UAO?I've towed across the country on 5W20 conventional, with a max load, at 80 MPH, up the Ike Gauntlet, with NO engine damage.
I believe it is relevant to his post, because HP engines can survive on 0W oils for hundreds of miles at high RPM's. In regard to ordinary folks driving ordinary cars, a new 2020 Mustang GT specifies 5W20.
I think i posted in another thread (or maybe this one) that Ford Australia updated the owners manual (3rd revision) for the 2015 Mustang to change the 5.0 oil from 5w20 to 5w30. I wonder if this was in response to what you mentioned, or if it was exactly what you mentioned.
I didn't check other years, i check the first year for the "international Mustang" and thus the same 5.0 engine in my F150 (albeit tuned differently) and it's in Ford's own downloadable owners manual, there are 3 revisions on Ford Australia's website and in the 3rd revision, the 5.0 oil spec changed from 5w20 in the first two revisions, to a 5w30 specification in the current/3rd revision....
I'd be surprised if Ford recommended 5W30 for any 5.0L Coyote, especially one year only. I find that modern Mustangs and F series control oil temps very well! Please let us know if you find a document on that.
