Will the "Big Kahuna" Fit and Work?
USAF Museum
The Mann W950/4 / Purolator L40316 / Wix 51333 "Big Kahuna" is listed on the Purolator site as having a UNF-1B thread.
The L30001 / 51515 / FL-1A / PH-8A filter is listed as having a UNF-2B thread.
What is the difference between these threads? I did some searching, but couldn't find a satisfactory answer, and was left with the impression that the "BK" might thread onto a UNF-2B mount. True or false?
If true, that brings us to the next questions:
1) Would the "BK" be suitable as a remote transmission fluid filter using one of those mounts that accepts the FL-1A?
2) Would the "BK" be suitable as an oil filter in an FL-1A application?
The key difference between the two size filters is the relief valve of 8-16 P.S.I. on the smaller filter, and the relief valve of 30 P.S.I. on the "BK".
L30001 specs
L40316 "BK" specs
Wix 51515 specs
Wix 51333 "BK" specs
Thanks.
One lousy little gage wire is the difference. The "B" and the # have to do with the actual thread size. Check the specs for a GM 3/4" male thread. Then try to thread a standard 3/4" SAE nut on it. Better get a big wrench.
If you have access to a Machinists Handbook (most libraries have one), all the details are in there.
Why not use a filter that is designed for transmission filter use?
[ April 07, 2006, 08:39 PM: Message edited by: Pete C. ]
You are correct sir.
I should have said a GM 3/4" filter stud. It is made to fit the oversized GM filter threads. Thus a standard SAE nut is an interference fit on a GM filter stud and an SAE bolt practically falls into a GM 3/4" filter plate.
The designation is, if I remember correctly, is a 10B thread spec. Almost a 7/8" size. But don't hold me to that till I can get at the specs.
GMs way ofindividualizing their filters.
