Hi everyone!
I have a question about my oil filter. I want to upgrade to a better oil filter for my 1980 VW LT28 2.0 Petrol. I have the details of my original oil filter which are as follows
Height: 123mm Thread size: 3/4 16-UNF Inner diameter: 62mm Outer diameter: 76mm with one anti return valve, Opening pressure bypass valve: 2.5bar
The one I am looking to swap to is a K&N HP-2005 because the specs all look the same apart from possibly the bypass valve PSI. I'm not sure if this is an issue or not, so I hope you can all help. The HP-2005 specs are:
Would this filter be a suitable replacement for the old filter? Or should I just stick with the original?
I have by the way asked K&N to verify this information, but they don't seem to want to.
Many thanks!
| Anti Drain Back Valve | Yes |
| Bypass Valve | Yes |
| Filter Material | High Flow Premium Media |
| Gasket Material | Viton Rubber |
| Height | 5.063 in (129 mm) |
| Outside Diameter | 3 in (76 mm) |
| PSI Relief Valve | 11-17 |
| Removal Nut | Yes |
| Style | Canister |
| Thread Specification | 3/4 In. - 16 |
| Product Style | Oil Filters |
| Weight | 1 lb (0.4 kg) |
Many thanks!
