Looking for a filter
Illinois
I need a filter that is less than 3.5" long, has a 20x1.5 mm thread and a seal ID of ~2.4".
I am trying to put in a filter adapter on my Hyundai Genesis Coupe and the filters used on it do not fit any of the Universal adapters.
Specs for the Motorcraft replacement filter are ....
FL-810
Thread Inside Diameter (in.): m20-1.5
Outside Diameter Top (in.): 3.15"
Outside Diameter Bottom (in.): 3.15"
Length (in.): 2.95"
Spin-On Filter: Yes
Bypass Valve: YES
Color: White
Burst Pressure (PSI): 300 PSI
Pressure Relief Valve: YES
PSI Relief: 13.5 PSI
Micron Rating: 80%@20um
Height (in.): 2.95"
Seal Outside Diameter (in.): 2.50"
Seal Inside Diameter (in.): 2.25"
Anti-drainback Valve: YES
Donaldson's site is having issues at the moment. It's easier there since you just put in the thread and it pukes out every filter in that thread. Accept/reject as needed ..x'ref as required
Item Number Item Description Attribute Description Attribute Value
P502007
LUBE SPIN-ON COMBINATION
Thread Size M20 x 1.5
Length 3.34" (85 mm)
Outer Diameter 2.68" (68 mm)
Gasket OD 2.67" (68 mm)
Gasket ID 2.15" (55 mm)
Relief Valve Setting 11-17 PSI (0.80-1.00 BAR)
Anti Drain Valve Yes
Efficiency 93.00 Percent
Efficiency 50% 20 Micron
Product Group F
P502009
LUBE SPIN-ON FULL FLOW
Length 2.52" (64 mm)
Outer Diameter 3.15" (80 mm)
Gasket OD 2.48" (63 mm)
Gasket ID 2.03" (52 mm)
Primary Application MITSUBISHI MD136466
Product Group F
P502010
Outer Diameter 3" (76 mm)
Primary Application MITSUBISHI MD322508
Product Group F
P502039
Length 3.93" (100 mm)
Outer Diameter 3.54" (90 mm)
Gasket OD 3.43" (87 mm)
Gasket ID 3.01" (76 mm)
Efficiency 91.00 Percent
Primary Application ISUZU 8944309830
Product Group F
P502047
Length 2.6" (66 mm)
Outer Diameter 3.55" (90 mm)
Gasket OD 2.58" (66 mm)
Primary Application RENAULT VI 5010372044
Product Group FH
P502049
Length 3.15" (80 mm)
Gasket OD 2.49" (63 mm)
Gasket ID 2" (51 mm)
Primary Application HONDA 15400-PR3-004
Product Group F
P502051
Length 3.94" (100 mm)
Gasket ID 1.81" (46 mm)
Efficiency 99% 37 Micron
Primary Application HONDA 15400-PH1-014
Application Note 15400-PK1-003
Product Group F
P502056
Length 5.64" (143 mm)
Outer Diameter 3.16" (80 mm)
Gasket OD 2.5" (64 mm)
Gasket ID 2.28" (58 mm)
Efficiency 96.00 Percent
Primary Application MAZDA 145623802
Application Note 145623802A, RF0323802
Product Group F
P502057
Length 3.35" (85 mm)
Gasket OD 2.56" (65 mm)
Gasket ID 3.03" (77 mm)
Primary Application MAZDA FEY014302
Product Group F
P502062
Length 2.56" (65 mm)
Gasket ID 2.17" (55 mm)
Primary Application KIA
Product Group F
P502063
Primary Application MAZDA JEY014302
Product Group F
P502067
Gasket ID 2.19" (56 mm)
Efficiency 92.00 Percent
Primary Application NISSAN, MAZDA, MITSUBISHI
Product Group F
P502076
Length 3.5" (89 mm)
Outer Diameter 3.43" (87 mm)
Gasket OD 3.33" (85 mm)
Gasket ID 2.81" (71 mm)
Primary Application PEUGEOT 110951
Product Group F
P502092
Length 3.23" (82 mm)
Outer Diameter 3.52" (89 mm)
Gasket OD 2.44" (62 mm)
Gasket ID 1.98" (50 mm)
Primary Application PROTON
Product Group F
P550067
ELEMENT, LUBE SPIN-ON
Length 4.98" (126 mm)
Outer Diameter 4.2" (107 mm)
Gasket OD 3.9" (99 mm)
Gasket ID 3.46" (88 mm)
Efficiency 50% 16 Micron
Primary Application MITSUBISHI ME014833, ME004099
Product Group F
P550158
LUBE SPIN ON
Length 5.37" (136 mm)
Outer Diameter 3.69" (94 mm)
Gasket OD 2.81" (71 mm)
Gasket ID 2.46" (62 mm)
Relief Valve Setting 8-11 PSI (0.60-0.80 BAR)
Efficiency 50% 27 Micron
Primary Application FORD E3TZ6731C
Product Group F
P550162
LUBE SPIN-ON
Length 3.39" (86 mm)
Outer Diameter 3.18" (81 mm)
Gasket ID 2.11" (54 mm)
Efficiency 99% 39 Micron
Primary Application ISUZU, HONDA
Product Group F
P550173
SPIN-ON LUBE FILTER
Length 3.16" (80 mm)
Outer Diameter 3.67" (93 mm)
Gasket OD 2.63" (67 mm)
Relief Valve Setting 8-10 PSI (0.60-0.70 BAR)
Efficiency 73.00 Percent
Primary Application CHRYSLER
Product Group F
P550383
LUBE FILTER SPIN-ON
Outer Diameter 4.13" (105 mm)
Gasket OD 3.92" (100 mm)
Gasket ID 3.52" (89 mm)
Primary Application ISUZU 8941145850
Product Group F
P550405
Length 3.98" (101 mm)
Efficiency 89.80 Percent
Efficiency 99% 40 Micron
Primary Application HINO 23304-78020
Product Group F
P550412
LUBE SPIN-ON BYPASS
Length 4.92" (125 mm)
Outer Diameter 3.64" (92 mm)
Gasket ID 2.08" (53 mm)
Efficiency 50% 5 Micron
Primary Application MAZDA SL5014V61
Product Group F
P550641
Length 2.59" (66 mm)
Primary Application YANMAR 11930535151
P550718
LUBE FILTER
Gasket OD 3.42" (87 mm)
Efficiency 50% 19 Micron
Primary Application ISUZU 8-9421-7272-0
Product Group F
P550726
LUBE FILTER
Length 2.78" (71 mm)
Outer Diameter 3.28" (83 mm)
Gasket OD 2.52" (64 mm)
Gasket ID 2.26" (57 mm)
Relief Valve Setting 11-15 PSI (0.80-1.00 BAR)
Product Group F
P550776
LUBE SPIN-ON
Relief Valve Setting 10-15 PSI (.69-1.03 BAR)
Primary Application KUBOTA 7000015241
Product Group F
P551257
LUBE SPIN ON
Length 6.38" (162 mm)
Outer Diameter 4.33" (110 mm)
Gasket OD 4.13" (105 mm)
Gasket ID 3.74" (95 mm)
Efficiency 99% 5 Micron
Primary Application ISUZU X13201012
Product Group F
P551264
LUBE SPIN ON
Length 5.62" (143 mm)
Outer Diameter 4.24" (108 mm)
Gasket OD 3.94" (100 mm)
Gasket ID 3.56" (90 mm)
Relief Valve Setting 20 PSI (1.38 BAR)
Primary Application KOMATSU/KOMATSU
Application Note DRESSER Z1402OF105
Product Group F
P551783
LUBE SPIN-ON
Outer Diameter 2.69" (68 mm)
Gasket OD 2.42" (61 mm)
Gasket ID 2.23" (57 mm)
Relief Valve Setting 8 PSI (0.55 BAR)
Primary Application HONDA 15410MM90003
Product Group F
P552849
SPIN-ON LUBE FILTER
Length 3.4" (86 mm)
Outer Diameter 2.96" (75 mm)
Gasket OD 2.7" (69 mm)
Gasket ID 2.33" (59 mm)
Efficiency 99% 36 Micron
Primary Application FORD, MAZDA
Product Group F
P555522
LUBE FILTER
Length 3.87" (98 mm)
Outer Diameter 3.12" (79 mm)
Gasket OD 2.45" (62 mm)
Efficiency 99% 50 Micron
Primary Application THERMOKING 11.5522
Application Note J.DEERE, YANMAR
Product Group F
