Longer version of Wix 51365 oil filter?
TN
Specs from the Wix site:
Product Specifications
[td]
Part Number:​
[/td][td]
51365​
[/td]​
[td]
UPC Number:​
[/td][td]
765809513655​
[/td]​
[td]
Style:​
[/td][td]
Spin-On Lube Filter​
[/td]​
[td]
Service:​
[/td][td]
Lube/Transmission​
[/td]​
[td]
Type:​
[/td][td]
Full Flow​
[/td]​
[td]
Media:​
[/td][td]
Enhanced Cellulose​
[/td]​
[td]
Height:​
[/td][td]
2.58
(66)*​
[/td]​
[td]
Outer Diameter Top:​
[/td][td]
2.69
(68)*​
[/td]​
[td]
Outer Diameter Bottom:​
[/td][td]
Closed:​
[/td]​
[td]
Thread Size:​
[/td][td]
20X1.5 MM​
[/td]​
[td]
By-Pass Valve Setting-PSI:​
[/td][td]
8-11​
[/td]​
[td]
Anti-Drain Back Valve:​
[/td][td]
Yes​
[/td]​
[td]
Beta Ratio:​
[/td][td]
2/20=6/20​
[/td]​
[td]
Burst Pressure-PSI:​
[/td][td]
300​
[/td]​
[td]
Max Flow Rate:​
[/td][td]
9-11 GPM​
[/td]​
[td]
Nominal Micron Rating:​
[/td][td]
21​
[/td]​
( )* denotes metric​
Gasket Diameters
[th]
Number​
[/th][th]
O.D.​
[/th][th]
I.D.​
[/th][th]
Thk.​
[/th]​
[td]
Attached​
[/td][td]
2.475 (63)*​
[/td][td]
2.173 (55)*​
[/td][td]
0.233 (6)*​
[/td]​
Note the 20x1.5mm thread size.
Thanks!
Is it for the Subaru in your signature, or the Nissan? On the Subaru, you should be able to fit a filter that's both wider and taller. In that case, I'd use a 51334 if you're set on using a WIX, which has a lot of filter media. If it can only be taller, there's the 51356, but it doesn't use much filter media for a filter of its size.
See this post for a list of filters with M20x1.5 threads with media area measurements. I would avoid both the WIX 51365 and the 51356.
Note that while the 51365 and 51356 appear easily interchangeable, the base plates are different in that one has a more concave recess than the other. This may well affect if the filter fully engages the threads and/or if the gasket fully compresses before the plate bottoms out.
No, but good catch. This is for my 2021 Kubota RTV-XG850 with the 2cyl gas engine. The Kubota part number is: HH1J0-32430
I found two viable replacements using the Wix physical search feature. The original Wix filter (eq to the Kubota P/N) is Wix 51365 and is about $15 at O'Reilly's. The two replacements are $26 and $42 at O'Reillys. No thanks.
Interestingly enough, my XG850 specifies the Wix 51365, while my 96 Pathfinder specifies the Wix 57365; both have 20x1.5mm threads and are 2.58" and 3.402" in length, respectively; diameters are similar. Si I can use the 57365 on both vehicles.
Thanks for the help!
