Shift time matters when you're doing it 6-7 times in a run instead of 3 or 4.Yes DCT automatic shifts faster and the car is awd. His 60 foot times were 1.8 and mine were 2.4-2.5. I gotta figure out how to get a better 60 foot time there’s higher horsepower Accords getting 1.9x.
In doorslammer classes, two-speed powerglides are still formidable when well-tuned.
60fts are all about traction, and thus weight transfer. In a FWD car that means the stickiest biggest tires you can fit up front with optimal tire pressure, chopping the front suspension super low to move the CG lower and reduce transfer to the rear, then staggering your spring preload to account for side to side traction differences with the open differential. IN other words, you need adjustable coilovers if you want to dial in better 60 ft.
