The preview owner must using a screwdriver or something that he put bunch of deep mark into the rear diff housing . I was going to use felpro gasket . But I think right stuff gray properly work better since it fill up those deep mark up
Mine look worse then that . The housing suffact is having deep gouges . I change fairly many rear diff and this the worse I seenBefore:
After:
Before/after. I accidentally instilled some gouges on this upper pan while removing the lower pan. A few seconds with a brown 3m roloc disc smoothed the gouges fairly well. You may want to consider doing the same.
I wouldn't take a Roloc to that or any engine or transmission for that matter, the abrasive dust generated by these things can severely damage bearings over time, I wont even use one under the hood for any reason. If the parts are being thoroughly washed and cleaned afterwards like a bare block or housing that's different.Before:
After:
Absolutely......I’ve always used a gasket and RTVWhen in doubt I use the gasket with a thin layer of RTV on both sides of it and have never had a leak with that combo.. That said I think you'd be fine with RTV only. I've never had one that clean before reassembly!
Same here. Every time.Absolutely......I’ve always used a gasket and RTV
Never had one to leak
We need the "this thread is worthless without pics"The preview owner must using a screwdriver or something that he put bunch of deep mark into the rear diff housing . I was going to use felpro gasket . But I think right stuff gray properly work better since it fill up those deep mark up
Drain and fill diff covers are the best for sure !Have not used tube goop on a differential in many years …
GM has a great gasket and the Jeep has drain/fill plugs …
I contained the dust, if-any. The entire process took under 3 seconds.I wouldn't take a Roloc to that or any engine or transmission for that matter, the abrasive dust generated by these things can severely damage bearings over time, I wont even use one under the hood for any reason. If the parts are being thoroughly washed and cleaned afterwards like a bare block or housing that's different.
If anything I would just use a very fine file to dress the area to remove anything proud of the surface and use RTV, you could also swipe a bit of JB weld on the mark and a couple of strokes with the file with restore the surface for a gasket.
