Originally Posted By: Quest
I wouldn't even think of adding MMO and the likes to upset an otherwise balanced formulation like PU or M1.
Esp. if you believe MMO has cleaning abilities, they why let it upset the additive packages in your oil?
If you believe MMO has thinning properties, then why let it upset the otherwise chemically-superior base oil (in syn such as M1, PU, etc.)?
Q.
I think Quest has pretty much nailed it. Mmo will thin your oil however the solvents will flash off in a rather short time leaving just whatever base oil they use and minimal anti-wear agents which will in effect dilute the original oils additive package and shortening the oils service life.
I'm a fan of mmo too and use it in many different applications. I've even got an inverse oiler on my daily driver however unless you have a deposit problem I don't see any gains by adding it,especially if the engine's internals are known to be clean.
The solvents which are iirc 70% of mmo's formulation will flash off pretty fast, I'm going to estimate within 1000 miles,so you'll be left with the 30% that's a mix of a mineral oil,scent and colouring and minimal(if any)anti-wear agents.
I don't think you've anything to gain by using it,but that's just my opinion.
Q.
