In reading thru BITOG, I've seen that some 0W-20 is lighter than others and I have a few questions:
1. I recall reading that Mobil 1 is on the heavier side. Is that when oil reaches operating temp or at start up or both?
2. I've used Mobil 1 0W-20 in both the 05 accord and 06 Odyssey since new. Recent oil change in Odyssey and used TGMO 0W-20. The difference at start up in terms of noise and there being no sluggishness is incredible.
3. I have a stash of Mobil 1 that I need to use up and am considering an MMO mixture in the accord. No apparent issues with the car, but I just want the lightest oil now that it's getting cooler and I figure an MMO cleaning certainly won't hurt anything
4. Is there any way to determine if a 20% or 25% mix with MMO will develop too light an oil?
The car is used for short runs (I keep it running when possible) except for a monthly shot down to Philly... About 200 miles R/T all highway
Some car specs: 160,000 miles on the car. 2.4L 4 cylinder. Car rarely sees anything over 2,500 rpm. May sit for a day or 2 without being run and a solid 5 minute warm up when starting. Only recently (last 2,500 miles or so) have I noticed the infamous Honda ticking starting... I haven't checked/adjusted valves yet. 5,000 OCIs with Fram Tough Guard or Pure Oil every change. No oil loss at all. PCV replaced routinely along with air filter (which I've learned I've been changing too frequently). Lucas UCL user until recently when I started a TC-W3 regime
These Honda engines are great and, as stated, no problems at all with the car. I just want to be proactive and keep ahead of the game
Thoughts?
By the way, I'm a strong proponent of MMO. That said, please keep the snake oil comments to a minimum... They're fun to read but do get boring when repeated over and over
Many thanks in advance....
Thoughts?
