I see API mentioned here a lot!
For the Pentastart 3.6L, just about any lube meeting API SP is going to work for 3k miles. That is a VERY short OCI duration in today's world.Max interval depends on the oil life monitor in the Jeep. So Ultra Platinum is as good as Amsoil SS if I change it every 3k miles?
That might be true. It certainly is not knowable. It is not something that can be determined with a simple UOA. But as stated Amsoil OE would still be in fine shape at 2X that as would Platinum and most any modern synthetic oil.Max interval depends on the oil life monitor in the Jeep. So Ultra Platinum is as good as Amsoil SS if I change it every 3k miles?
Technically it's possible. For example if the Chrysler cert revolved around emissions protection, your car is an oil burner, and your catalytic converter failed, Chrysler "could" void the emissions warranty on the cats because you used an oil which poisoned them. If you used a conventional oil and because you went the factory interval the oil sludged up, Chrysler could deny warranty work on the now sludged engine. If you used an oil of the incorrect viscosity (ex, 0w16, 0w8) then ya Chrysler could void your warranty if they decided to send the oil off for sampling.Amsoil does say Chrysler MS-6395 in the back of the bottle, but people say that is not a real certification like from Pennzoil and Castrol etc. I am confused.
API limits the amount of certain additives within fuel efficiency grades (30 grades and lower). Amsoil and others like Redline, HPL, will exceed those limits in order to extend the run time and cleanliness of the oil at the expense of cost. You'll also see from the majors (Mobil 1, Pennzoil, Castrol, etc) who sell a Euro blend in certain grades.I have sent samples of new oils, Pennzoil and Amsoil for analysis. Please tell me then why Amsoil is superior. It must be the more Moly
”People”? What people? People that wish to create contentious topics on Internet discussion boards as a hobby?Amsoil does say Chrysler MS-6395 in the back of the bottle, but people say that is not a real certification like from Pennzoil and Castrol etc. I am confused.
Precisely this.Not many hot topic threads left to post….
Thick vs thin
Warranty denial
Boutique oil approvals
Oci length
Owners manual recommendations
Bulk oil
Engineers and Cafe
Best oil
Most importantly, not using search function![]()
Oh no, don't let this become a new thread...What's wrong with Chrysler engines that they need a special oil?
