- Joined
- Oct 16, 2024
- Messages
- 78
Amsoil does say Chrysler MS-6395 in the back of the bottle, but people say that is not a real certification like from Pennzoil and Castrol etc. I am confused.
The answer is no if the Amsoil motor oil in question is the correct viscosity for your engine.Amsoil does say Chrysler MS-6395 in the back of the bottle, but people say that is not a real certification like from Pennzoil and Castrol etc. I am confused.
My owners manual says Chrysler MS-6395 0W-20. Not all 0W-20s have Chrysler MS-6395The answer is no if the Amsoil motor oil in question is the correct viscosity for your engine.
The precise language in your owner's manual is important, so please post that. Picture or exact quote is fine,
EXACT Words. Word for word. Thanks.My owners manual says Chrysler MS-6395 0W-20. Not all 0W-20s have Chrysler MS-6395
Abridged edition.EXACT Words. Word for word. Thanks.
But it must have API Starburst they say alsoThey recommend MS-6395, not require
You mean to my dealer?Why even go there..............?
Amsoil is missing that so their claim of Chrysler MS-6395 doesn't mean anything. That's why I am nervous about trying Amsoil![]()
What's wrong with Signature Series, why it doesn't have API approval?Because Amsoil easily meets the requirements.
If you want an API oil, Amsoil makes 8 different 0W-20's. 3 are API licensed. You seem to want the best, and did choose the best, but if you are nervous choose Amsoil OE or XL or even the semi-synthetic.
There are millions of threads on this. Amsoil simply does not like or want API control on the formula. Same as other top oil blenders.What's wrong with Signature Series, why it doesn't have API approval?
Ok, when investigating an engine warranty claim, do the dealers analyze the oil to see if I used an API oil or not?There are millions of threads on this. Amsoil simply does not like or want API control on the formula. Same as other top oil blenders.
There is nothing wrong with Sig Series.
There is no way a simple UOA could tell if an oil was API licensed or not. And it is missing the point anyway - I mean sure they could analyze an oil and see it’s grossly deficient in additives but I have never heard or seen such a thing.Ok, when investigating an engine warranty claim, do the dealers analyze the oil to see if I used an API oil or not?
Then I will use AMSOIL Signature SeriesThere is no way a simple UOA could tell if an oil was API licensed or not. And it is missing the point anyway - I mean sure they could analyze an oil and see it’s grossly deficient in additives but I have never heard or seen such a thing.
If a car manufacturer is going to claim an oil caused some engine failure it’s not just a verbal thing. They have to prove it. They don’t even try that. I mean this is an oil forum, been around near 25 years. No cases. Zero.
I have sent samples of new oils, Pennzoil and Amsoil for analysis. Please tell me then why Amsoil is superior. It must be the more MolyThere is no way a simple UOA could tell if an oil was API licensed or not. And it is missing the point anyway - I mean sure they could analyze an oil and see it’s grossly deficient in additives but I have never heard or seen such a thing.
No not just molybdenum. Or any single additive or any single base oil.I have sent samples of new oils, Pennzoil and Amsoil for analysis. Please tell me then why Amsoil is superior. It must be the more Moly
Max interval depends on the oil life monitor in the Jeep. So Ultra Platinum is as good as AMSOIL Signature Series if I change it every 3k miles?No not just molybdenum. Or any single additive or any single base oil.
Seriously if you are changing the oil frequently the brand won’t make a huge difference. What is the maximum recommended change interval? If you go there Amsoil will hold up better, shear less and should provide better wear protection.
