As far as I am concerned, the statement about Automatics not making it past 200,000 miles is a myth.
I've run several automatics well over 200K, my current ride's original trans lasted over 300K miles.
$5,000.00 to replace a 2015 Nissan CVT.I have personally owned decades-old cars with Torqueflites that never required rebuilding. Usually at 100K it would not be the transmission failing unless the owner never maintained it. Allowing for overall inflation, gasoline is less expensive today than it was 50 years ago. A Torqueflite can be overhauled for about $1000-$1500, and it is possible for an ambitious shadetree mechanic to do it themselves for much less. What does it cost to overhaul a CVT, dual-clutch trans, or ZF 8-speed? (If you want overdrive for better gas mileage there are transmissions such as the Aisin-Warner AW4 that add the extra gear without too much additional complexity and are nearly as bulletproof as the old Chrysler boxes.)
If you see how these things work and how little surface area these belts ride on to transfer all that power, it is a miracle these things work at all. That being said, I would think about getting one in my new car if they were cheap and easy to rebuild, but they are not. When the CVTs go they usually throw metal all over the innards and the whole transmission is toast and not rebuildable. $5k for a new transmission is a lot of money!My point of view as a mechanic that's seen the failures of these firsthand - most of them use a steel belt wrapped around pulleys....what happens if you bend a strip of metal enough times? It just snaps, and thats usually what happens to these. They are set up to fail in my opinion.
If you look at the surface area in a set of gear teeth in a transmission the actual contact points are pretty small too. All the engine power goes through that area as well.If you see how these things work and how little surface area these belts ride on to transfer all that power, it is a miracle these things work at all. That being said, I would think about getting one in my new car if they were cheap and easy to rebuild, but they are not. When the CVTs go they usually throw metal all over the innards and the whole transmission is toast and not rebuildable. $5k for a new transmission is a lot of money!
No, not even close. That gear tooth is more than adequate for at least 200% load and its spread over 3 teeth ( normal) at any time.look at the surface area in a set of gear teeth in a transmission the actual contact points are pretty small too.
My reply was clearly referring specifically to Parimento1's comment on the small surface area he perceived the power to be transmitted through on a CVT belt, not the mechanism of that power transfer or the number of teeth involved. I was pointing out that the actual surface area where the gear teeth that are transmitting power are in contact is quite small.No, not even close. That gear tooth is more than adequate for at least 200% load and its spread over 3 teeth ( normal) at any time.
The CVT relies more on stiction.
2 totally different things.
Yea, I was referring to the way that the CVT works, strictly on friction between the belt and the rollers, which seems pretty precarious. With a conventional manual gearbox, the gears are in constant mesh with the teeth. If that type of gearbox starts to slip, you have done something very very wrong to it haha. Even with a conventional automatic gearbox, the clutches are made out of high friction clutch material and there is good amount of surface area to grip onto.My reply was clearly referring specifically to Parimento1's comment on the small surface area he perceived the power to be transmitted through on a CVT belt, not the mechanism of that power transfer or the number of teeth involved. I was pointing out that the actual surface area where the gear teeth that are transmitting power are in contact is quite small.
Obviously the gear teeth are more than adequate given that gearboxes are, on the whole, quite reliable. The same, for the most part, could be said for CVTs.
However, thank you for your input. I guess I should be thankful you're not resorting to the caps lock key this time.
I don't view them as reliable. Right or wrong. Also, they just feel so disconnected.For your standard economy commuter, CVTs make a lot of sense. More fuel efficient and easier to keep a lesser engine in its power band. It can also be extremely smooth. I see no advantages to a slush box auto over a CVT in something like a Corolla, Civic, CRV, Forester. Yes, reliability was a concern at the beginning but that's largely been resolved. Modern CVTs are no less reliable than slush boxes.
I agree for trucks, they shouldn't have CVTs. But I always laugh when people say it's not sporty enough because it has a CVT. You want sporty, get a manual. There's nothing sporty about any automatic tranny.
I didn't deem it necessary to get the point across this timeI guess I should be thankful you're not resorting to the caps lock key this time.
At the end of the day … we have to like the “feel” of a vehicle … after renting several Nissan CUV’s with this transmission - I just plain don’t … in fact I like to feel a smooth but subtle shift and better yet, I now get to see D1 through D8 on the dashI don't view them as reliable. Right or wrong. Also, they just feel so disconnected.
At the end of the day … we have to like the “feel” of a vehicle … after renting several Nissan CUV’s with this transmission - I just plain don’t … in fact I like to feel a smooth but subtle shift and better yet, I now get to see D1 through D8 on the dash![]()
It doesn’t take long to get used to it. I actually dislike the fake shifting in my Rouge. You can avoid that by not pushing the pedal too hard. It acts more like a snowmobile then. I’m a fan of the CVT for sure, but it took some time.Almost 7 yrs ago I got a new Nissan Juke (NISMO) as a CUV just made more sense than anything else we looked at. Originally wanted the 6-speed manual, but that was only available in FWD. I really wanted the AWD system and in order to get that it had to be the CVT due to torque vectoring. The AWD model also has a better suspension and it was my first CVT. I'm not one to put much faith in reviews as we all have different experiences, expectations, etc. Of course I've read lots of complaints over CVTs, but will honestly say this ride has been fantastic from day one. It was something to get used to with no shift points, etc., but the performance in every day traffic to spirited mountain-type driving it just performs and has never given any sort of trouble. Yes it functions differently than a typical automatic transmission, but for me it's not a night/day feeling like some describe it. Maybe Nissan 'got it right' with this particular car, but I will drive it indefinitely and keep it in the absolute best shape possible, mechanically and cosmetically.
It never is.I didn't deem it necessary to get the point across this time
I am 100% certain that the 4L60E and whatever junk they put in early 90's crown-vic that I kept killing was way way worse than the 6 speeds in my CX5's, which perform flawlessly even past 100K miles.I believe so many people hate CVTs because an initial bad reputation is difficult to overcome. CVTs today are much better than they were were just a few years ago, and I would even say they're as reliable as automatics. I'm not sold on the notion that today's 6, 8 and 10 speed automatics are as reliable as the old 3 and 4 speed trannies, and those saying CVTs are expensive to repair, I doubt they're more expensive than a 10 speed auto would be. Also, anyone who claims cars with CVTs are boring to drive have not driven the Corolla. Yes, the Corolla is a boring econobox, but if you've driven any of the previous models, the new one feels like a sports car by comparison, and it's all because of the CVT. The CVT puts the engine right at the sweet spot for RPMs which makes the car very responsive. CVTs have come a long ways, but there will always be people who don't like them...
