Well, on my wife's 2001 Eclipse GS 2.4 SOHC 4 cyl with 179,000 miles, I have noticed one thing.
I use RTS 5W-40, have for a couple of years. After 1500-1800 miles, the oil doesn't move down a DROP. Then it starts dropping... it eventually gets to using a quart every 1000 miles around the 3000-4000 mile mark in the OCI, then a quart every 300-500 miles every 500 miles.
Change the oil, not a drop used for 1500 miles again.
What causes this in an engine. Remember I'm even using a thicker oil, RTS 5W-40. And I always top it back off with fresh oil. It doesn't smoke at all, no coolant goes in to the block. Motor runs fine, just has high mileage and we didn't get it from the best maintenance person, but we've done religious oil changes from 125k miles to nearly 180k miles.
Anyways, what causes that burn off to happen as the mileage gets higher, even when adding a quart every 500-1000 miles.
It goes like this:
up to 1500 miles - no oil used
2000 miles - maybe 1/4 quart used
2500 miles - whole quart used, I then top off
3200 - 3800 miles - another whole quart used... I then top off
It uses another quart by 5k miles, and I usually just change the oil by then.
But why doesn't it use ANY, not a drop to the eye, by 1500 miles?
It goes like this:
