Originally Posted By: JOD
Honda have done this for a very long time. I have a hard time believing "cost of ownership" had much to do with the decision since the same Hondas that called for changing the filter every other change also called for 30K valve adjustments and regular brake fluid changes... BTW, Ford used to also call for a filter change every other oil change.
I will say that on some of their engines the filters aren't all that accessible, so it's nice that they officially bless the long change for the filter. In a properly-maintained engine, I see zero benefit to changing the filter every change. OTOH, I like having immediate oil pressure after I change my oil. On my current car, changing the filter seems to drain most of the pump as well. My car always sound awful on the first start after a filter change (even with the filter primed). And, as I've read on BITOG, noise is everything... I'll be sticking with changing it every other oil change.
Noise on the first startup after changing the filter does not mean anything unless you can prove it somehow results in damage to the engine. To each their own, but I would change it out each OCI anyways. Not like its expensive. Im curious to know if a company can measure how much long it takes an avg filter to be fully used (full of dirt) before requiring replacement.. thatd be interesting..
