Originally Posted By: JOD
Can someone explain to me the issue that the "old" oil is going to cause? Most people don't even run the "old" oil to half of its useful service life anyway, and "old" old generally lubricates better than "new" oil anyway? Can anyone actually articulate a valid reason as to why leaving 1/2 a quart of oil in the engine is actually a bad thing (leaving "feelings" out of it for second).
- Fuel contamination
- Water contamination
- Metal particulate contamination
- Cost-benefit analysis
OK For the first three, 1/2 quart of slightly contaminated oil probably isn't a big deal with 3-4-5 quarts of fresh oil coming in on top of it. It's just not... optimal.
For the fourth, if you happen to start with a bad oil or failed filter, your engine only has to put up with it for one OCI. If you reuse either, then it's two (or more). That's the cost-benefit analysis that drives me to replace both at a regular oil change interval.
Originally Posted By: ZeeOSix
With spin-on filters, you would never know the shape it's in until you cut it open ... or I guess you could say it "operated properly" if the engine didn't blow-up.
I had a Purolator Classic that had a pretty good tear in the media, thereby allowing unfiltered oil to go past the media. That tear could have happened on initial start-up, or 5 miles before I changed it. I will never know ... all I know is that it wasn't operating properly at some point in it's use time.
We'll never know, but pre-filling the oil filter should prevent most media blowouts, unless it is just substandard media to begin with. But this is a good argument for 1:1 changes; a bad filter can only be bad for the interval it is allowed to remain on the engine.
Originally Posted By: Clevy
On a known dirty engine of course more frequent filter changes are required however if you know your engines clean,and you throw out your filter before 10000kms anyways you tell me more about yourself than words ever could.
The manufacture of one new automobile, or one replacement engine for that matter, has a huge environmental impact, from the mining, refining of the metals to the energy used for transportation of raw materials, parts, and finished products.
The environmental impact of maintenance MUST be balanced against the environmental impact of unneeded and avoidable repairs and replacements, and also considering the pollution created by engines pushed past their optimal lifetimes, where the definition of optimal lifetime is greatly defined by the quality of maintenance.
Even if you choose to dismiss or disregard the positive environmental impact of avoiding substandard maintenance ("tip top condition"), simply cutting out the filter, leaving the parts to drain in the funnel overnight, and recycling the steel takes care of the majority of environmental objections of 1:1 oil and filter changes. It gets more oil into recycling (and out of our groundwater) than tossing a 2-OCI filter uncut into the landfill, and the recycled steel has huge environmental advantages over mined and refined iron ore.
HF
