Why are there so many AWD cars now?
So e what but I believe the AWD adds stability in those situations.
Balance? Yes. Weight distribution is better. But Mazda does not have full-time AWD. As far as I know, once you reach a certain speed, it is FWD. Unless it transfers some torque (usually 10%) during cornering. Still, if there is no slip, only thing it will do is help with some oversteer.
It doesn't help you stop!
Oh, but there are some who think it does. Some lady I worked with was convinced that 4 wheel drive means you get 4-wheel brakes, and didn't believe me when I said all cars have had 4 wheel brakes for a LONG time.
Yeah, no center diff here with Haldex so it's just a clutch clamping/un-clamping at various pressures so it's not v. noticeable.
Gotcha. I'm not well versed in AWD systems post 2015ish outside of the Evo, GTR, and STIs. The Evo has a Torsen up front with a clutch pack for the center (ACD - Active Center Diff), and 2 clutch packs for the rear (Active Yaw Control) so technically open diffs, until they're not.
What's more confusing is the RS trims switches the active rear diff to a mechanical one because of WRC rules at the time (only 1 active diff allowed in WRC at the time.) It pushes the car into corners more but is much stronger than the active diff and is a preferred swap for drag racers on radials.
The Mazda's AWD during passive operation is something like 99% front and 1% rear or 98% front and 2% rear. I forget which one but they keep the rear just slightly active to reduce the "pause" before the system becomes energized.
Maybe, but really irrelevant with standing water. It is all about tires there.
  • Like
Reactions: Pew
Eh, I doubt it, unless you are hard on the gas in a near aquaplaning situation, then a full time AWD could prevent spinning up the inside front tire... Or I suppose if you were hard on the brakes, a full time mechanically linked AWD system can help redistribute braking forces a bit, but this is getting into rally racing territory, saving 1.2 seconds per kilometre at maximum driving aggressiveness type stuff.
No one should be driving that hard on street where these small differences matter, and in an emergency situation, its a very very small difference in performance, when the tires still make the most difference. Also the driver just slowing down a mph or two is much more significant than the type of drive system.
  • Like
Reactions: Pew
It is absolutely irrelevant. Driving on rails is due to suspension, which Mazda generally executes well.
Most are sending some power when starting to move. Once a certain speed is reached, usually torque in those vehicles is sent to the front wheels. Toyota until 2015, had in Sienna for example 100% FWD until it slips. But 2015 and later, as well as Highlander had an updated system where it would send during the initial move 10% to the rear wheels. Compared to Tiguan we have which has previous generation Haldex, it was definitely less capable, but still good enough to go through the worst blizzards in the Rockies.
Tiguan on other hand behaves in snow like a goat.
Prior to Active Torque control in the Sienna, which does provide some rear torque at initial acceleration, the Sienna had a fixed 50:50 ratio full time AWD system, which then used ABS to brake a slipping wheel.
The early Toyota RAV4 automatics electronic multiplate clutch AWD system may have worked that slow (starting mid 90's on the 1st gen), It's really no worse than a Haldex Gen2, but it wasn't 2015 that the rear axle gave some oomph an initial acceleration, as Active Torque Control was introduced to the RAV4 in 2006 (3rd gen)
For what they claim (bcs. every manufacturer claims that) what happened at 12-minute mark, should not happen:
It's no different than the "Off-road" mode on the Tiguan & Atlas. Press a button and the logic for the AWD & ABS system is different than driving on normal slippery roads. But you see, after pressing "Trail mode", it got out just fine.
This is also why subaru has "X-mode" on their cars.
And that's how he tests. He tests in default modes until it gets stuck, and then activates the other modes and gizmos to get it unstuck, to show a difference in behavior.
Not 3rd gen. 3rd generation initially had 100% FWD. I failed to be clear that I am talking 3rd generation. in 2015 they updated to send 10% back at initial acceleration.
I know previous ones were 50:50%.
While certainly not necessary, I really wish we'd have gotten AWD on my wife's 22 Santa Fe 2.5T. The engine puts out a goodly amount of torque and easily overpowers the front wheels, especially when turning and/or shifting the weight off the inner tire.
In Atlas, I never used off-road mode and went through much worse terrain than that. Steeper mixed with mud and snow, no gravel. Yet, no issues in regular drive mode.
The 3rd gen has Active Torque Control AWD, since 2010. So your date is off.
The VW Atlas forum got triggered when MotorTrend said the Atlas BaseCamp is useless with only 1 front wheel (with the Continental TerrainContact A/T) losing traction.
https://www.vwatlasforum.com/threads/motortrend-trashes-atlas-off-road-performance.6277/
No special mode could on the Atlas could get the car unstuck.
Like I started out this review saying, many who buy hardcore off-road-oriented SUVs for the occasional foray onto a beach or forest trail would likely be better served by a crossover SUV on all-terrain tires. So I planned to take the Atlas Basecamp out on some trails I'm very familiar with at California's Hungry Valley off-road park (an MT go-to for repeatable off-road testing). I was optimistic; my wife's Crosstrek Hybrid on all-terrain tires made the very trails I had lined up for the Atlas look like a walk in the park
I decided to start with the "sand pit" course first. Little more than hardpacked sand and the occasional football-sized rock, it is quite literally the least challenging section of the entire park. Lining up before the entrance to the practice area were offset moguls about ankle high. I engaged Off-Road mode and motored over the first couple, the Atlas picking up a front and rear wheel on each one. It was slow but steady going until the last "hill," when all of a sudden the front-left tire bit through the surface and started to spin.
And that was it. Despite having three other tires in contact with the ground, the Atlas was incapable of routing enough power to the other wheels. I tried every trick in the book to get the Atlas free—I reversed, turned off traction control, aired the tires down into the teens, rocked it back and forth, tried turning, wedged rocks, the Atlas' floormats, and eventually both the floormats and rocks under the tires to get the VW moving again. Yet all I got for my troubles was an overheated transmission (outside temperatures were a cool 55 degrees at the time) as the Atlas dug itself in deeper.
Despite the off-road-oriented tires, the Atlas Basecamp just didn't have the torque, advanced all-wheel-drive system, or stability control tuning to get it moving the 6 inches it needed to firmer terrain. After about an hour and a half of trying, I gave up and called the park rangers to yank me out. It took but a gentle tug by their Ram 1500 (and a lot of laughter) to free the Atlas and send me on my way.
Of course, it's the driver's fault, because if he drove faster and used momentum, he would not have gotten stuck in the first place. But using momentum is sort of cheating and puts you at risk for more unexpected vehicle damage, which is a no-no when you borrow a press vehicle.
And that's why the Youtube reviewers crawl off-road, to 1) increase the chance of getting stuck and testing the brains of the AWD system and other gizmos and 2) avoid the surprise trail damage that would get them on the ban list (See Everymandriver on why Toyota stopped lending him cars to review).
Yes if you search hard enough you will always find a example to back up your point.
You sure like to get argumentative on these threads.
Is that the same as that electric oil pump?
Please....
Toyota used 1 AWD system for the 3rd gen Sienna, for its 10 year lifespan, it's the Active Torque Control. Dynamic Torque Control was never available in 3rd gen Sienna.
Unlike the PQ35 Tiguan, which started with a Gen4 haldex and ended with a Gen 5 Haldex (around 2012-2013 was the switchover)
