Why add an oil additive?
My doubt is following:
Now take an oil at random, for example, Mobil 1 0w40.
I expect that this oil is carefully formulated an balanced to run into ours engine. Ok...
Now, adding an oil additive like Ceratec, Zddp, etc... could it change the chemistry of the oil ?!
If the top oils like Castrol, Mobil, etc..., are perfectly balanced, there any reason to adding extra Boron or Mos2 (or another antiwear sobtance) into the oil?
An oil has determinate quantity of antiwear molecule, a quantity originating from years of study and works in lab....the alteration of this quantity (caused adding an oil additive) is a good thing?!
And if the response is : "yes is a good thing", why the main oil companies do not add extra quantity of these additives into their formulations?
If for example Mobil 1 contains X number of Mos2 molecules (it's an example) and i add an additives based on Mos2, i will increase the primary and original X number to Y (with Y>>X), so, at this point, if is a really a GREAT advantage, why Mobil 1 for example do not contains originally the Y number of Mos2 molecules?
