SubieNate
You said “best”, in that case, in order:
1) HPL
2) Redline
3) Amsoil
Cost is no issue as you stated so go complete with oil and other fluids with the brands above.
To take it a step further, and not sure if the engine even calls for it (if not, then there is no notable performance enhancements etc) pump the highest grade octane just because “you can”.
You got comments and opinions. Do your own research here and you’ll come to your own conclusion. Cheers.
It calls for premium. I try to fill up at top tier stations. There's a Marathon and a Shell within a half mile of my place.
I've bought HPL for both the engine and trans. Going to use Bosch ESI6 for the brakes and the OE rebottled Castrol in the diff. It has electric power steering. The clutch uses the same reservoir as the brakes if I'm understanding right, so it should get some fresh fluid by proxy.
Cheers,
Nathan
