RhondaHonda, based on what you said, I went to look over the quote. It is for a 20KW. My neighborThe 24kw gen is probably a bigger engine and runs at 1800 rpm vs 3600 rpm. Much quieter and heavier duty.
While I understand the getting old part but being prepared doesn't mean getting gas when the roads are icy.I have propane. I want to run everything. I'm getting older and imagining me making numerous trips to get gas when
the roads are ice covered. LOL
The price difference is in the higher quality engine and alternator in the 24k.RhondaHonda, based on what you said, I went to look over the quote. It is for a 20KW. My neighbor
told me it was a 24KW and so I just assumed it was a 24KW. The quote plainly says Model 20RCA.
Please disregard my question as even though the price difference is still true.
It really doesn't matter as both the Kohler website and the company say I need a 20KW generator.
It's still interesting in the huge price difference.
AMEN! Still I gotta work on the "weakest" link.While I understand the getting old part but being prepared doesn't mean getting gas when the roads are icy.
Many people are like that no conservation of utilities. All lights on for the whole house, heat or Ac cranked up depending on time of year. They just pay the bills and don't complain. I'm the exact opposite, turn off lights and tvs and everything else when not in use. I make Improvements to save on energy costs.Don't be like my neighbor... As the rest of the neighborhood shivers in the dark, we see their house fully lit up, the decorative flood lights illuminating the exterior, water vapor coming from the furnace chimney... And then I see them drive down the street returning home! All that heat and light when they weren't even home!
We have a 4,000 watt portable generator to run the fridge, freezer, sump pump, and some lights. I can disconnect the gas furnace from the house power and pigtail it to the generator if it's an extended outage in the winter. I know this isn't what you're looking for, but it's proof that you don't need to run the entire house.
I am considering a whole house generator. I am leaning towards Kohler. I received a quote yesterday for a 24KW from a distributor.
Sounds like VFD … surprised a lightning storm has not killed them … you must have suppression for that ?We run entire house with 5 heatpumps (26 SEER), pool pump, 3 refrigerators on just 2600 watts of power. Since all appliances are Direct Current (as opposed to Alternating Current) and 240v there is no startup surge power demand as they slowly ramp up speed until setpoint and vary depending on demand. Converted years ago this way to be able to run for weeks on inverter generator (honda eu7000).
Also, we have a conventional water heater but installed a switch to change it from 240v to 120v and power use drops from 4500watts to 1125watts. Obviously, during an extended power outage we don't run oven, all stove top burners (induction) or max cooling or heating.
Have experienced 3 week total outages and it was no drama with this setup.
I went to their website to try and size it and came up with 20KW last night (after I got the original quote)
I have not questioned the original quote as to why he recommended a 24KW vs what the Kohler website recommended.
I am trying to get knowledge from you before I question the quote. Yes, I know a 20KW is a LOT cheaper. It appears to
be about 1/2 the price of a 24KW. Do any of you know why for only 4 more KW the cost is double?
Thanks!
EDIT EDIT EDIT
PLEASE NOTE &WKN((*L390VDJ84JVJ[WC[4U40SD......
MY QUOTE WAS FOR A 20KW. I GOT TWO QUOTES. ONE WAS FOR A 24K AND I ASSUMMED THEY WERE BOTH
FOR 24KW. THAT PART IS INCORRECT. YOU REALLY DON'T HAVE TO READ ANY FURTHER....
I'd hate to be in TX in general.When you look at the damage that freezing pipes could cost of your house floods, it's almost a no brainer. I'd hate to be in TX right now with all the blzckouts etc
So what? i dont see aproblem with that. They want to keep their house warm and lit from the generator, what does it matter?Don't be like my neighbor... As the rest of the neighborhood shivers in the dark, we see their house fully lit up, the decorative flood lights illuminating the exterior, water vapor coming from the furnace chimney... And then I see them drive down the street returning home! All that heat and light when they weren't even home!
