Not really.He certainly has the freedom to do what he wants. Doing whatever you want and flaunting your wealth can make you look like a jerk, however.
You aren’t being a jerk by having nice things.
Your post has nothing to do with the discussion.Give me your Social Security payout- take the kids out of Public School, and - you get NO unemployment insurance or medicare or medicaid.
See, there is rampant Socialism in America.
It's pretty funny; I am половина Россия, even though your note wasn't addressed to Me![]()
Make sure you do the math as far as gasoline is concerned. These things suck gas. At just 1 KW you need 4 gallons over a 24 hour period.Generator or Inverter generator (not sure if I need inverter or not).
Enough power to run a top freezer basic fridge, water heater (tankless gas), and a natural gas furnace, and maybe a couple lights or a radio.
Should be able to get it all setup for $1000, and stow it away in the garage for the next time I'll need it.
Correct. In short outages not a big deal. But a major long outage, you could have issues getting fuel.Make sure you do the math as far as gasoline is concerned. These things suck gas. At just 1 KW you need 4 gallons over a 24 hour period.
I would not go higher than 3KW. Smaller units deliver better fuel efficiency.
Diesel downside is that it degrades in storage. Unless you have it for Home Heating Fuel Oil not the best thing for homeowner to worry about turning fuel etc.It is difficult for me to comprehend why people insist on being able to run everything, as if nothing happened, in places where in reality, the extent of an outage is a few days or a week.
20 or 24kW?!? That’s insane. Everything can be run selectively when and as needed.
And if the reality is that there is real likelihood for long term outages (likes weeks to months), and you must maintain personal luxuries, I’d look at a diesel. In cases where infrastructure is gone, diesel will be easier to get, and save propane for other needs. BTDT.
Auto corrected from nasty grams, ie, hate letters. Sorry about thatWhat are Mast Grams?
The mis-behaviors have to be VERY irritating.
I will speak to the offender on the street if I can get a hold of them, and I'm usually pretty cordial.
A recent example. was The 7 acre Lot next to me was subdivided and some guy built a house on the top of the hill on ledge.
They had to blast rock - and that cracked my foundation and broke some windows - but that's ANOTHER story.
Recently a second owner added ANOTHER attached garage, which is situated right at my property line.
They installed four super-bright LED Flood lights around the eaves. These floods were on ALL NIGHT starting at dusk, shiningright in through my bedroom window blinds, keeping me awake and unable to enjoy the night and natural moon light and stars. This was going on for a over a month.
My Wife and I discussed putting a note in their Mailbox - since no one has a landline of record where we could to place a call.
As I was composing the note in my head, a electrician came and a half hour later - the lights went off. Fantastic coincidence.
and - Hurrah! Finally !
Now to do something about the dog walkers allowing their mutts to defecate around my mailbox.
More selfish, lazy morons moving in from Massachusetts.
I just cannot comprehend how unaware people are of their transgressions and generally societally poor behavoir.
I agree 20 or 24kw nuts but imagine AC is involved? I have a 6800W Nominal generator that backfields thru a panel to entire home and rarely trip a circuit unless I try to use toaster oven and coffee pot and well pump kicks at right time.
It was a reply to your snarky "Comrad " comments directed at dadto2; You put that in the discussion.Your post has nothing to do with the discussion.
This is the setup I’ve had for 20 years in my 3,000 sq ft house. I had a licensed electrician hard wire my Troy Bilt 8500/5500 generator at my back deck. I double check the main box to make sure all is well with the transfer switch as far as back feeding goes, wheel the generator to the connection box, hook up the 5 foot power cord the electrician made up for me to the genny and wall mounted box, fire up the generator and I’m good to go. NG furnace and water heater, fridge, upright freezer, 2 tv’s lighting etc. I can use one small burner on the electric stove without taxing the generator. It will not run my 4 ton ac unit but I rarely lose power during summer. The most I have used it was 4 days in 2014 during a big ice storm and the system worked perfectly, though I did throw an extra blanket on the bed at night when I shut the generator off. I would restart the generator first thing in the mornings. My total cost back then was roughly $1,200.After the power outage in Texas we have decided to get a generator.
I've lived down here for 10 years we have never lost power for an extended period of time. Even during tornados we only lost power for a short period of time.
My needs are very simple.
Not snarky at all. Your reply was very out of touch. That said, still not seeing your point. Who are you to say how someone should spend their money be it power from the grid or fuel to feed their generator? If I was to look your lifestyle over, I’m sure I’d find what I consider waste. That is my point.It was a reply to your snarky "Comrad " comments directed at dadto2; You put that in the discussion.
AFA the guy leaving tens of lights on in and around his house. It's just wasteful.
Waste is a SIN.
When we leave our home for a full day trip, We have one led lamp on near the front door in the living room.
Of course you would leave the heat on if its cold out, maybe at a lower level, say 63 deg F.
We ALL share resources. Conserve them.
No its not. With a whole house generator, you will not conserve anything cutting the lights off. A generator big enough to run an entire house will consume a minimum about of fuel. An led lighting circuit will not save fuel turned off on a large genset.AFA the guy leaving tens of lights on in and around his house. It's just wasteful.
Waste is a SIN.
Excellent pointsI am considering a whole house setup, because 20 or 24 KV generator allows my SO, or child, to simply live the way the normally do throughout the outage.
While most of the members on this forum can shift and manage total electric loads by switching breakers, or appliances, I would not want that responsibility to fall to a family member for whom that isn’t a reasonable expectation during an outage.
When large appliances, like the HVAC/heat pump, are involved, and the fridge is going to cycle on and off, along with an unknown number of lights, sizing the generator to handle the whole house avoids placing the management of appliance and electric loads on the family member when I am not home.
Alternatively, a Gen transfer panel that selects only particular circuits avoids having to size the Gen for the whole house.
When I lived in Vermont, the Gen transfer panel powered well pump, septic transfer pump, refrigerator, furnace, and hallway and bathroom lights. That limited load to about 7K and the Gen was sized appropriately.
Off the transfer were the electric range, washer, dryer, kitchen GFCI, majority of household outlets, my shop sub panel, garage and exterior lights... essential systems only to keep our load within the size of the generator we already owned. Cost was an issue for us.
I think you may have misunderstood his post. But without a live conversation we may not know.He was judging somebody because they were simply prepared... If you don’t see anything wrong with that, I have nothing more to say to you.
Remeber the problem with getting Fuel - I wasn't able to get gasoline as all the pumps had no power with 20 miles
