dnewton3
Staff member
Note that in Pablo's application (Transit), the engine will be longitudinally mounted (like a F150) and also detuned from typical F150 ratings.
F150 ratings: 400 HP / 500 fl-lb torque
Transit ratings: 310 HP / 400 ft-lb torque
The detuning is necessary because the Transit (and pretty much most vans) don't have the same ability to reject heat from the cooling system(s) due to the tighter engine bays. The detuned engine will have less stress on it than a typical F150 application, all other things being equal. Assuming they use the same/similar transmissions, it, too, will see less stress from the lower power level relative to the truck application.
