Originally Posted by KrisZ
The higher the RPM the less MOFT is required. It's the low spinning engines that need more MOFT. Stevie, this is basic BITOG stuff.
Where did I quote MOFT? I was only talking about it being a 20wt.
Youve made that implication many times in this thread, maybe without realizing it, you don't need to use the acronym "MOFT" to talk about it.
When asked about Toyota owners manual and a clause about using thicker oil for high speed driving or towing, you said that your Highlander revs really low at highway speeds, then you mentioned several times that 4 cylinder engines rev higher at highway speeds and are still fine or 20w oil.
This implies that low RPM is better suited for lower viscosity oils that higher RPM. This is not the case and that is why your owners manual mentions using heavier oil.
Of course a very high RPM cruising, like on Autobahn doing over 100mph, and wide throttle opening, heats up the oil a lot more, therefore it affects the MOFT to the point where the higher rotational speed cannot compansate for crankshaft wabble in the bearing, hence a higher viscosity lubricant is required.
You took it at that. I was referring to heat generated by the friction.
